Transmission line enclosure
  • #16
    Martin King's software, which I've been using for over 10 years.
    Paul
    Originally posted by relder View Post
    What are you using to model Paul?
    • #17
      In case you aren't aware, I sent you a Private message yesterday.
      Paul
      Originally posted by B King View Post
      Thanks Paul. Above and beyond the call. If this will work, I'll document the build of these bad boys. No big hurry as we are leaving on a trip Sunday and we'll be gone for a couple of weeks. As soon as we get back, I'll fire up the table saw.
      • #18
        Paul, I'd be interested in that design also. Fooled around in HornResp and tried to find a solution for a different woofer, but the same type of form factor.
        Tangband W6-sub
        • #19
          Don, Brian King is leaving Sunday with his wife to spend 2 weeks in Spain. When he gets back I will complete the design and send it to him. I will share it here at that time unless you can't wait. If you need something sooner, send me a direct email (I'm pretty sure you have my email address).
          Paul
          • #20
            Paul
            I'm in no hurry, my friend. As always, appreciate your assistance.
            Built a test box with a folded TL and Rival 176 mid-woofer similar to your spec,
            and it sounded great. So I've now got the TL bug.
            Tangband W6-sub
            • #21
              Don,
              Which Rival are you using and would you care to share any pics of your box/construction? I'm wanting to try my hand at TL's soon.
              • #22
                Paul
                This sounds like a very interesting design, Paul. Looking forward to seeing how this turns out. I am in no hurry either. And thanks for sharing.
                Bill
                SideTowers: http://techtalk.parts-express.com/fo...corundum-build
                • #23
                  Originally posted by Waboo View Post
                  Don,
                  I used the Rival 176-CP-08 (although the 176 line is all pretty similar).
                  First off, I'm not a TL guru - I mess around a bit with HornResp, but it can't model some of the things that
                  Martin Kings worksheets can do (like move around the port).
                  I may be wrong about all of the following:
                  CSA is very critical for a MLTL - I used 7.5 x 6.5 for a single R176-CP-08. - tried to get the line about about 38" long.
                  Came up with (3/4 inch BB ply) external 9W x 14.25D x 23.75H. Internal divider about 15.75 long.
                  Think I used a 3 inch port about 4 inches long. Box was roughly 52 Liters.
                  This was just a test to see if I like the "TL sound", and I liked it a lot.
                  IMHO, gave a lot of solidity to the bottom end.
                  Hope this helps!
                  Tangband W6-sub
                  • #24
                    While CSA is important, the most important factor is getting the optimum tuning frequency (in any type of TL). Once you have that determined, the CSA, which, for a specific line length, controls and determines the bass response. The optimum tuning frequency is somewhat dependent on the overall bass response shape you desire. I always model for an essentially flat response from 1 kHz down to the knee in the response curve, but others might prefer a more gradual rolloff starting at a bit higher frequency. Also, the optimum tuning frequency is affected by the driver's fs and Qts. Anyway, in an ML-TL the system is tuned by two factors; one is the 1/4-wavelength resonant frequency from the line's length (which in your example below would be ~94 Hz), and the second is the mass of air loading the end of the line and working on the volume in the line.
                    Paul
                    Hope this helps!
                    • #25
                      Thanks Paul. I still have so much to learn. I really MUST get Martin's sw working.
                      Tangband W6-sub
                      • #26
                        Don, you're welcome. To illustrate better the issue of tuning frequency, I've attached 3 comparison graphs showing a too-high tuning frequency, a too-low tuning frequency (which some may choose or prefer) and what I use and consider to be an optimum tuning frequency The red line in each graph is the predicted anechoic system bass response for the same driver in the same ML-TL but with different port lengths to create the different tuning frequencies.
                        Paul
                        Tuning frequency too high.doc
                        • #27
                          Hope this helps!
                          Thanks, Don. That driver cone looks very similar to the SS 18W/8545K. Glad you're diggin' the TL sound. It sure sounds like some good fun.
                          • #28
                            Paul
                            [ATTACH]n1403250[/ATTACH]
                            <hangs head>
                            <promises to study harder>
                            Uh, thanks Paul! Very informative.
                            TBH, I'm likely to build a test box and try those alignments. I usually like an EBS alignment, because I feel that room gain fills
                            in a good part of the "droop". But I'll want to hear the difference in a TL design.
                            Thanks.
                            Tangband W6-sub
