High powered sealed sub + room eq.
  • #31
    If you're trying to create linear bass output I would highly recommend following the Geddes multisub approach and run 2 or preferably 3 small subwoofers (they don't need to be small, but with 3 of them running, they can be). It's not that hard to do if you have the subs hooked to a minidsp or whatever.
    You may find that following those guidelines will have much greater effect on perceived bass quality than things like sheer output, extension and porting options.
    Regarding subwoofer drivers, I am running CSS sdx10s at the moment, which I got on sale, but in general, Dayton makes the highest value subwoofer drivers available right now. Someone can correct me if I'm wrong on that point, but the reference, ultimax and dvc lines seem to offer more for less than anybody else.
    • #32
      A guy at Diyaudio was spouting about how good push pull config is, but he never elaborated. He did make it a point to use multiple "small" drive. Those Cerwin Vegas are cheaper and have better specs (higher xmax and BL and sens), you should take a look at the one I'm fancying "VPRO154D". Otherwise, I completely agree about the Daytons.
      Gebbes Multi sub approach aye? I just found an article, time to read. Thank you very much for the information. If You anything about this "push pull" theory I'm all ears too.
      edit: Oooooooh yeah I know about running multiple subwoofers, I just can't. Its too much gear, though its tempting. For some reason I was envisioning multiple subwoofers in a 3 way fashion. This has to do with placing multiple subwoofers within the room. Its best practice, but for me, this will be in the future.
      • #33
        I have one large sub in a small room. I don't use it for music, because I don't feel like I need to. For HT though, it's rather entertaining. Some movies have LFE low enough to physically shake my chair, even though I hear virtually no bass. I'm powering it with one channel of a 5 x 80w Harman Kardon amplifier. The sub is 4 ohm, and the amp can provide 150w I think into 4 ohms. I believe that in the past when I was obsessed with explosions in movies that shake the room, I measured to determine the SPL that was loud enough to really feel. By memory, I think 107dB was the point that impressed me. I could hit that mark with a 10" Peerless in a band-pass enclosure. My current 15" sub is simply a large ported box. That 107dB is probably in the 20 to 30 hertz range. I mention these details because music is not as demanding, and I doubt you would play music loud enough to need 107dB below 200hz. I may be wrong. If you are playing music at say 93dB, how loud is the bass. Well, crank the system to what you consider adequate, and then turn off everything but the subs, and measure the spl. I think you might be surprised. I just tried it with my system, and it was about 10dB lower. The battery is weak in my meter, so it might be off a little. Lastly, the room might alter the bass. My room adds a bunch, but I've heard rooms that are hard to get any deep bass.
        For your music mixing, I would think that a good ten and 100w would be sufficient. Laptop battery is about gone. Got to go.
        • #34
          I mix/master music, I am frequently staring at a frequency analyzer and while doing the work, adjusting those frequencies into "place". The work alone, makes you very familiar with sound/audio engineering. its like I have pieces of the puzzle from sound engineering and the rest of the mysteries are within loudspeaker theory and design plus room acoustics. Its funny because the majority of studio engineers I've come across, are clueless when it comes to speaker design, the ONE TOOL, they NEED to do the job *facepalm**facepalm**facepalm*
          I definitely know if and what music occupies what areas of the frequency range, and EDM and Rap have information in the 30's. That's why I aim for flat to 30. Flat to 20 would be preferable for any sound engineer, maybe I want to mix/master movie sountracks, like you said, HT....well someone has to tailor those sounds before it his the big screen, and if your system isn't flat in the area of critique, you are going to have issues of your results translating to other systems, though there are some other methods/theory, it all starts with having a super smooth frequency response.
          I'll often high pass a mix at 30-35hz... its kinda a golden rule. So music can be less demanding but from the engineering side, it is, or at least can be. When ever I set up room eq, I get a snap shot of the whole frequency curve, with my current 12"s my roll off is somewhere the 30's
          I tried your test at full volume and I hit 110 with or without the mains on, leaving the subs on. The problem is I'm also clipping the amp.....which was the first reason to upgrade my subs. The plate amp is the complimentary amp of the subs, if I turn the limiter off I'm probably just about to the point of clipping the xmax. The subs aren't powerful enough, long story short. I don't mix at these volumes, but when you add room correction into the equation, I think I am hitting the limiter at lesser volumes,but not so obvious. This system also doubles as a HT for movies and video games.
          (my house curve target was flat with a 2db bass tilt, I can't remember how close I actually got it with room eq, but it was close)
          So, I have something to share, I think I'll start a new thread to discuss it, but did you guys know that the way the lines are organized on a frequency chart is not without coincidence!? Where the vertical lines are spaced father away, that is the area where the ears are least sensitive.....or more most sensitive....I can't remember which....but with the correct information, it would lend tell to where to place a crossover....potentially
          • #35
            I'm surprised that you might listen that loud. The tune that I tested was on my Steely Dan Two against nature disc. To me it was plenty loud at 80dB. Maybe the low battery voltage is affecting the scale on my spl meter. I used to listen at 90dB routinely. If the music you mix is going to be played loud, I see your point. You need accurate playback at the SPL your customers would use. It would also seem that bass is more prominent in what you mix, than it is in most rock that I listen to. What EDM type music is available on you-tube that I can try on my system? I want to hear something that will tax my setup.. (Maybe not as loud, but I do like to push the system on occasion.) Have you ever heard "Spies" on Telarc? Uncle Festive? Ed Mann "Get Up"? Yellow Jackets "Time Squared"? These are some of the discs that I play louder than usual. The Spies disc has a warning about keeping the volume reasonable until you know if the system can handle it without breaking something.
            The JeffB modeling software I use shows how much power the speaker actually uses at different frequencies. If you compare a sealed and ported speaker, you will see differences in the power consumed because of the impedance. You can compare sealed with boost, to ported without boost.
            The bass in my room is uneven, but deep. I sit against the wall. My sub has eq, and is very flat below 40hz in my small room. I mostly cut 45hz., and above 80hz.
            • #36
              I've come to understand that sealed is less efficient than ported. A person who's opinion is respected, has said, in this thread I believe, that he could not tell the difference in spectral decay of a sealed vs a ported sub, generally speaking, by ear. I'm ok with all that but show me a sub that is as good as the subs discussed, will play a f3 of 30hz or better, in a 3.5ft3 ported box. I want to try sealed anyway but I am not set in stone. The box size is though, as well as range expectations.
              "You need accurate playback at the SPL your customers would use" The average playback level in a club is 116db. Though I know and entertain the philosophy, there are other philosophies that suggest something like 86-87db to be the best mix volume.
              Normal studio equipment has limiters to prevent damage. In my case, the subs will be ridiculously over powered that I'll never actually turn it up, loud enough to damage anything. The amp has a clip indicator, maybe a limiter, and the rms of the speakers I've surveyed are more than double the power I'll need for playback.
              Also, my comment about frequency graphs needs clarification. On a proper spectrum graph, the octaves are spaced equally, so though there is some truth to the sensitivities of the ear, where the graph is wider, the sensitivity is to pitch discernment not exactly spl...still I'd think those areas are wise to avoid with an crossover, yet because crossover curves are derived with roll offs per octave they are not disturbing the balance......yet, the area between 1khz and 5khz is most sensitive to spl, and in a perfect world I'd think you'd avoid a crossover there. Just my theory. I think its easier to space the high pass and low pass on the mid, wide as possible, leaving the largest pass band possible to be afflicted by crossover.
              • #37
                Xmax and BL won't tell you how a woofer will behave in a box. Based on the ginormous Vas and fairly high Qts of that 15" CV, the required box size for a reasonably flat response will be absolutely huge. It's designed for a car, where you can get away with a high Q sealed box and rely on cabin gain and EQ to flatten it out. I haven't modeled it myself, but I suspect if you pop the parameters in WinISD you'll find the Dayton much more appealing when compared to the CV.
                Wogg Music
                • #39
                  I gotta be careful with winISd, the files from loud speaker database can be missing a spec or to, and it doesn't always have the omh spec in the right place, but I did plug those woofers into the winISD and the CW vega out performed the Dayton ultimax, but once again I may have a spec out of place
                  "Based on the ginormous Vas and fairly high Qts of that 15" CV, the required box size for a reasonably flat response will be absolutely huge. It's designed for a car, where you can get away with a high Q sealed box and rely on cabin gain and EQ to flatten it out."
                  Well sir, you know more a bout this topic that I do! I am listening, all ears, over here. The high damping factor is a good thing for a tight driver, is it not? I use room eq as a standard so unless the response characteristic isn''t smooth, is that not enough? In winISD the driver as barely an audiable bump towards roll off?
Name:
ID:	1405121 This modeling is for a 3.5 sealed enclosure.
                  • #40
Name:
                    You may be quite right, those curves look awful similar... if I get a minute I'll plug them in BassBox and see if it agrees. The Q of a sealed box is quite different than damping / tight driver. Usually Qtc > 0.7 creates a response peak above roll off that has to be dealt with and has lots of talk about "boominess" or other completely unverifiable stuff people say about their audio systems.
                    My guestimate is based on lots of modeling, where I've observe that for a sealed box, a driver with a Qts of ~0.39 typically hits a sealed box volume about equal Vas for a Qtc of about 0.7. Honestly though, some of the other guys have more accurate in head modeling calculations. Chris Roemer comes to mind, that guy seems to be able to model enclosures and whole crossovers in his head.
                    Wogg Music
                    • #41
                      While searching through the loudspeaker database I noticed a trend. There are more than a few speakers with very similar specs to the Ultimax. Some of the speakers, had the same...exact...diecast spider frame. So I imagine that for those who know where to go, a particular frame and voice coil, and woofer diaphragm, is a best bang for buck, at a large volume purchase....so a buncha speaker manufactures jump on it. Just my guess.
                      • #42
                        Some one made this for me =(
                        Click image for larger version  Name:	 Views:	1 Size:	599.3 KB ID:	1405148Guess its not a huge downer, aside from the lower xmax, the performance went up the different specs.
                        • #43
                          Originally posted by JRT View Post
                          Camplo... If you do not already have Unibox, then download it from Charlie Loab's website. Use that to model one Dayton RSS390HF-4 subwoofer driver and one RSS460-PR passive radiator with PR moving mass increased to a total of 1100 grams in 150 liters net enclosed compliant air volume, without leaks and without stuffing, and with 400 Watts applied.
                          Here are the associated links.
                          Unibox
                          http://audio.claub.net/software/kougaard/ubmodel.html
                          Dayton Audio RSS390HF-4
                          http://www.daytonaudio.com/specs/spe...p?prod=295-468
                          Dayton Audio RSS460-PR
                          http://www.daytonaudio.com/specs/spe...p?prod=295-506
                          • #44
                            ...the required box size for a reasonably flat response will be absolutely huge...
                            Not specific to this woofer, but generalized consideration of fundamentals, consideration of Hoffman's iron law of loudspeaker enclosures... All else equal, a smaller enclosure requires more power to produce the same SPL over the same bandwidth. All else equal, more power into the box on crests in the program material leads to larger changes in temperature in the voicecoil which result in larger changes in series resistance within that voicecoil, increasing dynamic compression and the nonliear distortion associated with dynamic compression, and increasing the more audible linear distortion associated with varying Q-factor. Without getting into silliness of extremes, the power conversion efficiency of a moderately large box can be an element of improved performance, and going smaller can degrade performance.
                            • #45
                              That's because Dayton doesn't make drivers. For that matter very few companies do. Even those who assemble their own drivers do so using components that are mostly Asian sourced. Some companies that are large enough, like Eminence, have proprietary components produced exclusively for them, but even Eminence uses some generic components, the LAB series being one example.
                              www.billfitzmaurice.com
