I come asking for some wisdom, in the area of sub-woofer implication. I want to upgrade my subwoofers a pair of ported 12" Kevlar woofers... The bass is respectable from current setup, but with best practice in mind, I would like to invest in improving performance in this area. The subs complete a system with 2-ways that take over after 200hz or so. Think three way with low xover point to the woofer and high xover point to tweeter.
I've heard of people using overpowered sealed subs to create really accurate systems. Sealed advantages for subwoofer performance; better impulse response, less delay, etc, and then the short comings; less bass extension as opposed to ported systems, so with an over powered sealed sub, we use room correction eq to extend the range of the subwoofer, which is only possible with a luxury of amp headroom and sub xmax.....
This is for studio monitoring, so application is of concern, just wondering is this a good idea for what I'm looking to do. I'm not sure how powerful of sub system I would want, 500rms8ohms per sub (2 subs) is a good starting point I think. I know of xmax calculators to help determine what type of driver specs to look for...Not sure which starting f3 is too high to try and extend with room eq...I'm hoping for some insight, correction if needed. I could always just build some nicer ported subs....I did like the novelty of the over powered room corrected seal sub....what do you guys think?
I am also open to product suggestions if you know of one that would suite my need.
