Crossover beginner needs help!
  • Crossover beginner needs help!
    Hello,
    I am new to crossover design and I need help!
    I tried to design a 2 way crossover for the "Dayton Audio DSA215-8 8" Designer Series Aluminum Cone Woofer"
    and the "
    Dayton Audio AMT2-4 Air Motion Transformer Tweeter 4 Ohm" in the free software VituixCad without much luck..
    I am a total beginner and I dont know what I am doing. Could someone please help me out? I attached a picture with my current mess :D
    (sorry for bad english , don't judge me thanks :D)
    The first thing to understand is what data you are using. Garbage in / out applies. If you are using manufacturer supplied FR and impedance (ZMA) files, then you should "adjust" these to meet your intended baffle shape / size and placement. Basically - the frequency response is affected by the baffle.
    Unless you have a very large (infinite baffle) - aka wall mounting, a speaker box has what is called "baffle step". This is where high frequencies (> 1000Hz) are higher SPL than lower frequencies by about 6dB. You might see this as a gradual rise in repsonse on a woofer from 100Hz up to 1000 Hz. You need to take this into account so your speaker doesn't sound bass weak.
    I can document a process to follow, but this is more than a single post can answer.
      An 8" 2-way isn't the easiest.
      Your selection of an Al cone woofer makes it worse - 'cause metal cones "ring" (like a bell).
      An AMT tweeter (probably) makes the situation even worse, as they typically can't go very low (not fam. w/the 2-4 model and can't look it up right now).
        Thanks for that fast answer!
        Could you help me design a crossover for those 2 speakers? Im in kind of a rush and I dont think I got time to learn all about that topic in that amount of time.
        I plan to mound both speakers flush with the front of the speaker. I can give you all basic data and informations you need. I would appreciate your help very much!
        Thanks in advance!
          What is the rush? If you don't have the time to learn, then what goals are you trying to achieve?
          As Chris has stated, those drivers are going to be difficult to make work. Can you share what lead you to those driver choices?
            Really, you've been getting help since December. Are you actually making these designs? Is that rendering in post #4 real? It's all so odd.
              The reason we might seem dismissive - is all too often people flip flop with driver choices, goals then apply constraints that make a design really limited.
              Then we invest in helping you
              Then you change your mind and we have to reset throwing away our time.
                This post may help you with the process. If you aren't prepared to read it, then you can't blame us for not spending our time to help:
                https://www.diyaudio.com/forums/mult...asurement.html
                  I'm sorry guys I don't want to waste your time. It's just that I want to design my own speakers and allways when it comes to the crossover I get frustrated and search for help and find out that the speakers can't go together for different reasons that I did not think of because of my lack of experience in this topic. I want speakers for my desk with good power and warm sound. I now realize that my decisions with my selection of drivers are everything other than good. My options are a bit limited because I life in germany and can't get all good speakers. Last thing I thought is that I will need 8 inch speakers so it won't be enough but now I realize that I'm wrong with that decision. My limited time I mentioned is because my speakers I got at the moment broke and I want to build my own ones with my dad in the near future.
                  I really appreciate all your help and it's not my plan to waste your time.
                    Sheesh. This kind of thing happens about once a week now. I'm curious: why is your time so valuable, but not the people here?
                    Francis
                      There is a learning curve and design is time consuming. It is not a slap-dash proposition. I recommend starting they way many of us did. Build a kit. Sent from my iPad using Tapatalk
                        Agreed, post #9 reads like spam.
                        John H
                          A new breed of pushy, technically incompetent bots? The mind boggles...
                          Francis
                            Could just be the younger generation self entitlement......our 26yo son thinks the world owes him a favor, then when no favors happen it’s everyones fault but his own!
                              Heh. Well maybe. Although I've known people from 8 to 80 who have that attitude. But it is odd the guy made a nice drawing of the speaker, has been on the project since December, ignores everything he has been told, but is suddenly in a big rush. Very bot-like.
                              Francis
