Help with a variation on Pete S. 3Way Peerless Design
  • #16
    Originally posted by jhollander View Post
    Yes
    Sorry poor grammar.
    Mr. OP - *did* you re-extract......
    • #17
      Here is another box model, starting from scratch after a reboot so no data was left in PCD. This time it came out much better looking but I am surprised at the amount of overlap and the fact that I cannot get a nice deep null at the crossover. I am fairly certain that I shouldn't be worried about that, but when I try for it, it just doesn't happen.
      Does this model including box response look better now?
      To Dave B. I extracted -after- splicing in the box model and diffraction.
      • #18
        The woofers are running up too high. They should be -6dB at about 400hz.
        • #19
          I tweaked it a little bit, but I see that as I try to make it more perfect the impedance in the upper bass begins dipping down to about 2.5 ohms, which worries me with the amp I current have (Akitika GT101).
          • #20
            It seems to me there is no baffle step compensation. You can see this in two places. The "midrange bulge" - where it looks like you have nice phase tracking, and the fact the midrange transfer function isn't 3+ dB below the woofer (level transfer).
            You should start with a net system sensitivity as a goal for baffle step compensation - then go from there. In this case I would target ~ 88dB assuming you've correctly modeled the woofer bass rolloff
            • #21
              Ok edit - I was going by the graphs in post #15. your latest looks better
              • #22
                It looks like you are shooting for 4th order woofer-midrange? Have you tried 2nd order acoustic? This might raise impedance. Lower your XO point (assuming your mid can handle it) to ~ 250Hz
                • #23
                  My sim also drops low in the bass. I'm not sure there's a way around it.
                  • #24
                    I tried to model with different bass roll-offs but it turns out worse. I always end up with a resonance bump from the crossover which then requires notch filter and further complicates the crossover. Since I am using the same 830874 drivers as woofers and midrange, I don't think it's really a problem with all 3 drivers playing with so much overlap in this case. I think this model is probably the best its going to get without either a more complex crossover or at least building it and seeing what the real world project does.
                    • #25
                      Do you already have the drivers?
                      Also, are you OK with a full baffle step compensated design? If the speakers are too close to the wall, the tonal balance might not be what you want.
                      The woofers could be wired in series.
                      l can show you my sim, but it's likely got the same issues.
                      • #26
                        Yes, already have the drivers. Yes, full BSC is expected as these are playing in an open basement well away from the walls. I see Pete's original design model (without box effects) also has a low 3 ohm impedance in the upper bass area.
                        • #27
                          It's weird. It drops due to the woofer filter, not the mid, or tweeter. The tendency is for the filter to boost around 100hz also. Must be due to the relatively high resonance.
                          • #28
                            I'd try a damped second order. Lower the woofer cap and increase the inductor. Add a resistor after the woofer cap to damp down any peaking
                            John H
                            • #29
                              Everything is helpful, thanks for sharing.
                              • #30
                                I further revised the model, looks similar overall, but I think its a bit better blend of the drivers. I tried a damped second order from John's suggestion, but it lowers the sensitivity too much requiring high resistors throughout the rest of the circuit to lower everything down to the woofer level.
