Which terminal is +
  • Which terminal is +
    Help! Airborne RT-4001 has no terminal markings. Which is positive, the small or large spade? I don't think the old battery trick works with AMTs.
    Thanks.
    By common conventions, the big terminal is positive.
      As further confirmation, on drivers I've used with terminals that were marked with polarity symbols or colors and also had one terminal wider than the other, the wider terminal has always been the positive one.
      Paul
        Thanks dcibel and Paul. I may get these together before Friday!
          Yup... I assumed big terminal was positive, so if you treat them that way, the crossover schematic will work as intended.
          Sehlin Sound Solutions
            I check mine, well their twins, and sure enough they don't have any markings either.
            Until you look closely....real close....between the bar that holds the spade terminals and the rear of the tweeter body....
            Thankfully, the diaphragm itself has color coded lead wires as you can see from those pics above.
            Good that you got it sorted out regardless.
              They make two types of push on spade connecting female terminals, one is wide and the other is skinny......As for the reasons why (besides the obvious of positive and negative) one is wider then the other I don't know maybe others can shed some light on it.
                Now that's a thorough explanation!
                  Thanks for that confirmation, Scott.
                    Poka-yoke... Prevents manufacturing errors when assembling.
                      Markings sometimes wear off, or don't get properly printed, too.
                      Francis
                        I have some Audax drivers that have the small terminal as positive
                        A mains
                        The Ventures
                        Open Invit8tions
                        RSR
                        Sound Troopers
                        Acorns
                        442
                        DGBG's
                        The Monuments
                          Well... they are French after all!
                          Craig
                            Well, I connected + to the large terminal 'cuz that's the way Scott designed 'em.....and they sound terrific that way!
                            Nice work Scott!!
                              Some drivers use large terminal on both sides usually when the terminals are on opposite sides.
