Theorized and proven: "Zingers", an InDIYana 2019 8" 2-way design...
  • Mainframe
    Like this
    As long as the braces are opened up to transmit air flow, that should work fine if you don't stuff the bottom of the box. IMO/IME, stuffing the bottom 5-6" of a tower box is a good idea to prevent the column resonance, even if you lightly stuff the rest of the enclosure. If you do fill that area, you'll need to rotate the inner end upwards. If you have kids/cats/kittens and they play around these, you might want the inside end upwards anyway to prevent a toy or critter getting placed inside the cabinet.
    Later, and thank you for the condolences,
  • Mainframe
    Thanks Wolf
    Any objections to this port arrangement?
    P.S. sorry to hear about you forums friends early departure rock on in the next life dude
    Doesn't matter.
  • Mainframe
    Wolf Starting to get bits together. Does the bend in the port effect velocity/resonance? or doesn't matter ?
    There are a lot of reasons 10" 2-ways are rare birds that I won't go into right here in this thread. I've only seen a couple commercial designs and 2-3 DIY that did it justice.
    Just suffice to say that 8" 2-ways are difficult in most aspects to get right. Being as such, 10" 2-ways are not impossible, but are very close to it.
  • bgymr
    Ear splitting late night drunk music. Sounds like it should be a song.
    I'm new to this and am in the process of building the Zingers. I think they will fit well into my living room. My Advents I had were 10" 2-way speakers. Is there a reason when I see 10 woofer in a DIY speaker it's in a 3 way arrangement. Could 10" 2 way speakers be done with a reasonable budget?
    Ports are preferably out the back. I did side firing because mine will be close to walls behind them. Bottom is okay as you suggest.
  • Mainframe
    I know, i know. Speakers dont last long around here. Thanks for the fuse tip. Ill give it a go and report back. Does port position matter ? Im gonna go tube so will have to have a bend in it or go bottom firing with feet.
    More than Classix 2.5 is likely, but drunk ear-splitting levels with clipping amps are never good for any speaker. If you want a security guard, add a 1A slow-blow fuse on the positive input. I was able to get my stand-mounts pretty darn loud, and no stress was heard.
  • Mainframe
    Hi Wolf , keen to give these a go floorstanding. Built the classix 2.5 and we bottomed out the woofers the first night. They do alright for TV but the music later in the evening was too much for them (think large room, few beers, 165w Sony receiver) . Do you think these Zingers would take a bit more power than the classix 2.5?
    My impression of the "4 (edges) on the Floor (standing)" cabinet is below just in case anyone was wandering approximate dimensions. Numbers are internal dimensions, so you'll have to add the bracing and the cabinet around those numbers. Please ask if you have any questions.
  • silverD
    Excited to see your build of these djg! I see that you are making room for the Zingers and getting rid of some other gear.
    House of cards. My Zinger interpretation. They are shorter and deeper, same width and volume. My vision is even more retro than Wolf's original. I will start my own thread after a bit of progress. I was able to get them out of two 2'x4' handi panels, after I brought the height down to 15.75". 15.75" x 14" x 11.5".
    Just took some measurements of how I voiced them out back in April. These are the first measurements as a system. Honestly, they aren't perfect and likely far from it, but they are enjoyable. The way the tweeter rolls off gradually takes the bite out of the transition, and the left channel measures worse than it sounds. Also of note- they were not measured in the same place in my living room. There could very well be some room interference.
    Right:
Name:	Zinger Right.png
Name:	Zinger Right_HD.png
    Left:
Name:	Zinger Left_HD.png
    I like these a lot- they are immensely fun!
