4inch mid woofer option?
  • 4inch mid woofer option?
    Question for the masses... after seeing Tomz's summer winds and seeing the use of a.5.25 woofer at the base and my last failed attempt at a boombox, I would like to know if people have any input in relation to a 4"
    https://www.parts-express.com/dayton...8-ohm--295-416
    https://www.parts-express.com/peerle...-ohm--264-1065
    They both aesthetically look similar, have a F3 of 55-60hz in a similar size enclosure and last but not least a couple of bucks different. I also still have a Peerless PR laying around, which I think is similar but agreeing with Chris would prefer to use the electrical conduit and make a port, also the enclosure modelling is a bit funky with the PR's for me.
    I didn't like how my last adventure ended and considering a full gut job and recycling the ND65'S and what ever other components I have lying around and use a mid for the bass. Unsure if I would use the PE 2 1 HiFi amp and get one mid or use the DTA2 and attempt a cross over with the full ranges (nd65-4ohm), regardless I will be begging for some assistance if I go the later
    https://www.parts-express.com/dayton...eaker--295-424
    this driver sounds pretty good and might be worth considering.
      There was a small speaker at InDIYana in the themed contest that used the TCP115 and sounded good (I don't know if it was 4 or 8 ohms). Everyone in the room was shocked at the bass.
        Agreed. The TCP115-4 is also used in the Dayton Audio MK402 which gets generally positive reviews.
        Dayton Audio MK402 4" 2-Way Bookshelf Speaker Pair
          Peerless SDS 4", I think 830955.
            Cheers for the input guys, out of curiosity i punch the data into WiniSD for the peerless 8ohm, DA TCP 4/8 ohm and purely out of curiosity the same in the TEBM65 as i know what it can do in the same size enclosure (being 0.17-0.18cuft).
            not sure why a smaller full range appears to model better than a dedicated mid? even at a enc size of 0.125cuft (cheated with the bass box recommendation for the peerless on PE site) the graph barely goes over 0db, with the exception of the TEBM.
            When referencing F3 is that just -3db on the chart, OR is it -3db from the peak (tuned value)?
            I don't know if maybe i'm not using the software correctly when it comes to the mids or maybe i just found the sweet spot for me with the FR's.
              I asked in a recent thread about preferences for a small hump in that 50-100Hz range and got some good input. Post #8 referenced some observations by Jeff Baggy that were useful.
              In general you would want a flat frequency response like the red line (Peerless) and then a smooth roll-off. But some people prefer some non-flatness, according to responses in the thread above. For the transfer function, F3 is at the -3db on the chart. For actual SPL, change your signal until the cone excursion hits xmax (or xmax + 10%), then change the graph to SPL. The F3 is still the point where it is -3db from flat, but now the decibel levels are showing you the loudness at xmax.
                The drivers that are peaking at the end have the port tuning too high. The one with a hump has the box too small.
                  the end one being the TEBM's will spike no matter what size box in the model. for example i went up a few and the spike makes it look like a playground slide. I have actually made desktop speakers with a 0.18cuft box with them and they actually sound terrific, there could be a possible solution for this, maybe i did enter in the TS info correctly for that particular driver. the other possibility is i'm comparing 3 mid range in a 4 inch to a different style of driver in a BMR.
                    It might not actually be too small of a box as suggested, but using a driver in a vented box that likely ought to be run sealed. If the volume looks right, and the spectral shape is what you are looking for, try stuffing the snot out of it. The ripple will be minimized.
                      Looked at it and the BMR driver is wonky. Doesn't act like any woofer I've ever modeled. Best I can get it with WinISD is 0.19cuft box and 53Hz tuning. A 1.25 inch port that is 5 inches long would work. Even with that expect a 3dB hump at 100Hz, and extension to about 50Hz. Limit of about 8 watts before you hit xMax limits on the suspension, which puts the speaker around 90dB.
                      Polyfill stuffing is probably a good idea regardless with a ported box that small.
