Now THAT is a crossover
  • Now THAT is a crossover
    Saw this @ Stereophile.com.
    Page here:
    https://www.stereophile.com/content/...stereo-amp-and
    I wonder how the speakers would measure. With that many parts, they should have been able to get them about ruler flat.
    All that for 20w/ch. This kind of equipment is all about exclusivity and appearance it's got little to do with audio performance sadly.
    Paul O
      Ah, come on.... Mine looks better....
ID:	1414979Click image for larger version
ID:	1414981Click image for larger version
      Mind you, most of the coils were superfluous with only 3 of the majority running at any one time for a coil-type comparison. AND- I added 4 parts for the Xpad circuit as well as changing a couple more values in optimizing for the newer TSCW636 Supreme woofers.
      Yeah- I know that theirs is indeed larger, but at least mine was with a larger purpose involved.
        And that's why Stereophile is no longer relevant.
        www.billfitzmaurice.com
          Page here:
          Or flip it around and ask what crappy drivers they used that require such massive amounts of massaging. And even so, I bet they ignored the whole subject of deep-sea bioluminescnce.
          Francis
            To you and me maybe, but there are still plenty of audiofools out there that think they can hear the difference between Ethernet and USB cables.
              That actually is a nice looking piece of kit, especially when once considers the reasons behind it.
                I'm kind of curious what that crossover is all about. There were a lot of parts in Joseph Audio Infinite Slop xovers, maybe that is doing something similar but with exotic parts?
                Because honestly I don't know how you'd build a crossover with that many parts under normal circumstances?
                Edit to add: Apparently they're "constant voltage" crossovers:
                http://evolutionacoustics.com/evolut...brochure-4.pdf
                Looks like the impedance doesn't vary much?
                I donno.
                  I donno.
                  Maybe. Considering that modern amps are very tolerant of impedance swings, that seems like a dubious reason to massively complicate the crossover.
                  Francis
                    Oh I'm pretty sure the actual reason is to provide some snake-oil type sales literature to unsuspecting audiofools that will sleep better at night knowing their speakers provide an even load.
                    Gotta differentiate. Even if that means your crossover is a two-man lift.
                      The Snake Oil is strong with this one.
                      https://www.evolutionacoustics.com/?...28613281250000
                      Due to the extreme engineering behind these cables, proper burn in will begin to occur after several hundred hours. These are probably some of the heaviest and largest cables in the industry with an extraordinary amount of copper. Therefore, be patient, because when adequately broken in their performance is sublime.
                      Francis
                        I'll translate that for people following along: "The cables won't be broken in until long after the return window has closed."
                          Lol
                          Francis
                            With the massive amounts of copper in that crossover, I bet they take forever to break in, too!
                            Francis
                              I bet if I plug them into 600VAC 3-phase they'll be broken in no time.
