Now THAT is a crossover
  • #31
    Originally posted by Wolf View Post
    Ah, come on.... Mine looks better....
ID:	1414979Click image for larger version
ID:	1414981Click image for larger version
    Mind you, most of the coils were superfluous with only 3 of the majority running at any one time for a coil-type comparison. AND- I added 4 parts for the Xpad circuit as well as changing a couple more values in optimizing for the newer TSCW636 Supreme woofers.
    Yeah- I know that theirs is indeed larger, but at least mine was with a larger purpose involved.
    Yup, and your inductors are hand-wound and poly-dipped. Things of beauty they are.
    They probably used off-the-shelf stuff for that X-over.
    But did you ever put a spotlight on yours? Maybe the warmth from the incandescent bulb gives the music a tube-like warmth.
    TomZ
    • #32
      Where does it describe the function of the magic smoke?
      • #33
        Originally posted by dcibel View Post
        Fluff-free translation: it's a series crossover.
        Anyone using the phrase "not in the signal path" for any electrical components is lacking an understanding of electronics. All crossover components are in the signal path.
        ^^This
        If you interpret that load of poop as each driver is in series with each other and straight to the amp, that means they're ignoring the parallel filter components in the series topology, which of course is wrong. Plus, that means each driver needs only 1 or 2 components and is limited to a first order electrical filter. I don't know WTF they're doing with the rest of the components.. super excessive parallel notches everywhere?
        Also.. series would more accurately be described as "constant current" since all series components share the same current (again... ignoring the required filter components). Voltage is the only thing that changes in series circuits. They seem to be dumb on several levels.
        Wogg Music
        • #34
          Funny how the term constant voltage crossover has changed. When Small wrote a paper on them what it meant was that the summed output was flat with zero phase. Obviously a parallel 1st order crossover fits that definition as does the B&O filler driver and the TP 2nd order crossover I developed years ago based on Small's work. One thing about CV crossovers is they typically have really poor vertical polar response. Sometimes you just have to shake your head and look away.
          John k.... Music and Design NaO dsp Dipole Loudspeakers.
          • #35
            Yet, their crossover doesn't affect the signal in the slightest. I suspect we just don't have the mental capacity to grasp the awesomeness.
            Francis
            • #37
              Originally posted by Kornbread View Post
              How do they sound?
              Irrelevant!! Stay on topic!
              • #38
                For that price they'd better sound good. Really really good. And I'd still resent the bizarre pseudo-science the company touts as "information".
                Francis
                • #39
                  Pretty much everyone sells snake oil, from your local used car salesman, to your elected officials, to just about any corporation. Sadly, tt's a way of life these days.
                  • #40
                    And you're free to gladly accept it. I don't.
                    Francis
                    • #41
                      Yours looks better? How so? More colorful zip ties? Unused zip ties?
                      Craig
                      • #42
                        Accept what?
                        • #43
                          Originally posted by philthien View Post
                          Edit to add: Apparently they're "constant voltage" crossovers
                          LOL, Constant Voltage crossovers have horrible lobing and constrain high or low pass to 6 dB/octave.
                          Simmed this all on a Vax 30+ yrs ago. Ack!! Pass!!
                          • #44
                            I wonder if it can make a bose speaker sound as good as the Revel Salon 2's? LOL
                            • #45
                              Horrible lobing yes, constrained to 6db/oct, no.
