Woofer question: One big versus several small?
  • #31
    Originally posted by mikec View Post
    too much time to think---
    Has anyone listened to similar enough designs to decide if there's a noticeable difference?
    For example, nine 4" drivers or four 6" drivers would have same area as one 12". If all the drivers had similar properties would there be a difference?
    Would multiple smaller similar drivers have a higher total cost?
    Would the narrower baffle have an advantage?
    I cant give you a technically reasoned answer. But I can give you my cheap *** opinion after having attended Axpona this year and auditioned 100 or so systems. In a nutshell my wife and I preferred the sound of single large woofer systems 12 or 15 inch. Some were horn loaded, some bass reflex, none that I can remember were in sealed enclosures. Often times they were paired with horn loaded mid/high. Small or multi woofer dome tweeter System after system started to sound the same, too perfect, too clinical, with little apparent differences even at $20,000 price differential. The big boxes were just plain fun, especially on jazz with horns and stand up basses, Ella Fitzgerald, frank Sinatra, count Basie big band recordings from the 50's. Hearing the great baritone Joe Williams and the count Basie band we looked at each other and smiled. My wife and I are both dancers so we hear a couple live dance bands per week, big bands, small bands, all jazz related, often stand up bass, occasionally a slower bass like bass guitar (IOW bass with no attack) bass guitars don't swing too good. Some of our band even use a tuba player for the bass, 1920's Charleston bands. I trust my wife's ears, she isn't thinking of technicalities. After Axpona I visited here with my first post asking about doing a 15 inch system with horns and sensitive enough to hear the noise floor of my tube amps! I have a great deal of respect for folks here working all the math and voodoo, I'm not anti intellectual, a good large woofer speaker still needs that background. But this is just an empirical opinion.
    as others have said large woofers simply "go lower" and have low-side headroom (foot room?). It's like if you compare the bass of a bass guitar where the plucked string is less that 3 feet long to the string of a stand up bass where the string is 6 feet long. For the 3 foot string to produce a low note it must be very loose, whereas the 6 foot long string can still be wound tight. Plucking the short string will still produce the note, but there will be no "attack" to the note because of such a loose string. It will be "slow bass". Whereas a 6.5 foot tall stand up bass when plucking that long tight string will produce an "attack" to the note that is exponentially louder than the 3 foot string on the guitar can ever produce. Musically this is what gives jazz "swing", the fast attack and decay of the bass with a 6 foot long very tight string. Large woofers can be "tight" with low excursion like the 6 foot string of a stand up bass. Small woofers need to be "loose" with high excursion to get the same note, like the short string of a bass guitar must be loose. So small woofers have "slow attack" in the bass, like a bass guitar has slow attack because it has such a short loose string, the compromise is to loosen the string a lot to achieve the same note. The compromise with a small woofer is to give it large excursion, but then it loses its attack to reproduce the same note as the large woofer which needs very little excursion, like a long but tight stand up bass string.
    • #32
      • #33
        To recap my analogy of small and large woofers to bass guitar and stand up bass strings...
        String length of the bass instrument is analogous to the speaker diameter (short string = small speaker and long string = big speaker)
        String tension of the bass instrument is analogous to the speaker excursion (low-tension string = high excursion speaker and high tension string = low excursion speaker)
        The needed plucking force of the bass player is analogous to the watts you need to run the speaker (hard plucking of a loose string is needed to get the same power of soft plucking of a tight string = high watts to move long excursion vs low watts to move low excursion speaker). Additionally the stand-up bass has a "cabinet" so it needs no electricity. The bass guitar has no cabinet, it is a slab of lumber. The stand up bass is a big resonant cabinet.
        Slow bass of a bass guitar vs fast bass of a stand up bass is analogous to the slow bass of a long excursion woofer that achieves the same note via excursion vs the fast bass of a low excursion woofer that achieves the same note via size.
        • #34
          I think it's a case-by-case basis whether multiple smaller woofers of the same effective cone area can effectively replace a larger woofer. I needed a 15" driver to go below a 511 horn, but the drivers I saw that would be appropriate, going smoothly to the 800Hz crossover, and up to 1.6kHz without crazy peaks etc were expensive, starting at $300 or so. I ended up using four 8" 830869 Peerless drivers. Same cone area as a 15, but the overall price was lower. It's true the Xmax isn't what a typical subwoofer driver would give, but the pro drivers we considered didn't have a large Xmax either. The 8s were placed in a square pattern below the horn to give a similar polar pattern as a 15. Using the 8s allowed us to angle the front baffles, each vertical pair of 8s angling outwards about 14 degrees to help with baffle diffraction. The cabinet is tuned to 28Hz, so deep bass for music isn't much of a problem. So far everybody who has heard the system is impressed.
          Francis
          • #35
            Mounting biggest subwoofer in the world (32") on car roof - YouTube
            • #36
              Damn djg you looked younger then I imagined. LMAO
              • #37
                Being both a speaker designer and bass player, electric and standup, I can say that there's no such thing as 'fast' or 'slow' bass. The main difference in electric versus acoustic is that the tone and timbre of electric comes primarily from the amp and speakers, that of acoustic from the instrument. The size of the body of the acoustic is simply too small to support anything approaching flat response to even the second harmonic, let alone the fundamental. This results in accentuation of the mids and highs compared to electric bass, and that's what those who don't actually know what's happening call 'fast' bass. Test side by side an acoustic and an electric standup bass, the latter in the form of an Ampeg (the instrument, not the amp), and an electric bass. The acoustic bass will sound thin in the lows, prominent in the mids. The Ampeg and electric will sound similar in the lows. The Ampeg will have a different midrange timbre, but a fretless electric will duplicate that.
                www.billfitzmaurice.com
                • #38
                  I find it pretty sad that people are still caught up in this "fast vs slow bass" nonsense. I have read how people go out of their way to look for low Mms subwoofers, thinking that the lower mass will be "faster" and that 'faster sound" will be... better??? As if this is the only parameter that matters...
                  These folks don't seem to have a clue about the time-domain transient/impulse response, how it is related to the frequency response, and how it changes when the driver is band limited by a low pass crossover.
                  Charlie's Audio Pages: http://audio.claub.net
                  • #39
                    Fast bass from Yamaha.
                    Fast Bass Boat - YouTube
                    • #40
                      Originally posted by djg View Post
                      fast bass from yamaha.
                      fast bass boat - youtube
                      lol
                      • #41
                        Not to hijack the thread but I find this very interesting. My brother In-law (I am not a musician) just moved from an electric bass to a stand up and since he plays large venues he has been on a quest for an amp and speaker that doesn't not make his stand up sound electric. My first thought was a very large light cone with high efficiency so cone travel is minimized at relative volume levels but I really have no real understanding of what I am dealing with here as far as reproducing an accurate stand up from a speaker and amp.. I would think you would want to avoid as much bass boost as you can with the electronics. I could be wrong.
                        BSME
                        Kannapolis NC
                        • djg
                          djg commented
                          Editing a comment
                          Trollbot sweety hijacked the thread.
                      • #42
                        It will never die. It's easier to parrot stuff from the internet than to actually do math and engineering.
                        Francis
                        • #43
                          U
                          • #44
                            How did that happen? Sorry.
                            • #45
                              You don't need to use a lighter cone, ie., lower Mms, which usually results in higher Fs, although you could. What stand up needs is flat response to at least 10kHz, what it doesn't need is LF extension below 100Hz. That's characteristic of good self powered PA tops.
