What is End Correction and what do i do with it?
  • What is End Correction and what do i do with it?
Name:	winisd ns3 193.jpg
ID:	1416382 I just downloaded winisd and modeled my drivers. One of the parameters is for End Correction with a value of 0.732. What does this mean and what am i supposed to do with it? Also under the drop down button it gives the option for Two free ends, one flanged end and two flanged ends. I assume that refers to either a straight cut port or a rounded end/ends of the port. Each option changes the port length and port resonance figures slightly. How do i interpret and use these figures in building the port?
    Just pick the option for the type of port you want to build. Do you have a straight port, a port with one flared end, or are both ends flared? It will adjust your length slightly to achieve the same desired tuning based on your selection. A port with 2 flared ends should be slightly longer than a straight port to achieve the same tuning, as the flared section is equivalent to a small section of tube of slightly larger diameter. Adjacent walls also effectively increase the port length slightly which won't be considered by most simulation software, so if you have adjacent walls to the port you may end up needing to shorten the port slightly to tune it, but in reality it's all just nitpicking as 1-2Hz difference in tuning is highly unlikely to be detected by your ears.
      dcibel, is that Scott Owen in your avatar?
      It is estimated that one percent of the general population are psychopaths - New Criminologist: Understanding Psychopaths
        It sure is, from some show in the late 90's I think. I thought it was so cool when he would get up and ride his stand up bass like a surfboard while playing.
