New Build Advice...
  • #61
    Originally posted by Navy Guy View Post
    Have you simmed your baffle info? It doesn't look like it. I wouldn't use a 4th order network on the woofer either.
    He's showing -6dB at 1k on the filter transfer. That's for the baffle step compensation.
    • #62
      Here's what I've come up with using a similar woofer file, and altering the zma. Try the filter and see how it looks.
      It's a second order filter with a cap bypassing the coil. The other three parts are a notch for near the 1k range.
      Click image for larger version  Name:	ne180 estimate.jpg Views:	1 Size:	373.5 KB ID:	1418740
      • #63
        Here's a baffle sim to show what my filter attempts to compensate for partially.
Name:	baffle effect.jpg
        • #64
          The tweeter seems to have that hump out of the box:
          • #65
            Here are the on axis F/Z files:
            RS28A-4_hor_deg+0.frd RS28A-4.zma NE180W-04 ZMA.zma NE180W-4 FRD on axis.frd
            • #66
              I'll try your filter tonight. I appreciate your help, I'm on the west coast so you're probably in bed. I'm trying to absorb some of this info, but it is a bit confusing. Thanks again
              • #67
Name:	woofer new filter.png
                here is the woofer with the filter you recommended. still a spike at 1090 hz but that seems to be in the raw fr as well
                • #68
                  Try this.
Name:	ne180 filter.jpg
                  • #69
                    And this.
                    • #70
                      More.
Name:	ne180 rs28 filter rersponse.jpg
                      • #71
                        Click image for larger version  Name:	Tweeter Raw.png Views:	1 Size:	20.5 KB ID:	1418744
                        Where did you get the tweeter frd from? Mine was much smoother. Edit.. Found another frd that was identical, so I guess it's accurate.
                        • #72
                          We should modify the woofer frd to make it accurate for an on baffle response. Not sure how to do it, but should be easy, if someone can point us to the software that does that.
                          • #73
                            I got the tweeter frd from the rs28a-4 product page on pe
                            • #74
                              Use the Response Blender to add the baffle response to the woofer and tweeter files. The Blender can also add in the box. Add the tails in the blender and extract minimum phase. Use geometry to estimate the driver offset(s). The SPL match between the drivers is a crapshoot...
                              John H
                              • #75
                                Btw I thought these were suppose to be against the wall?
                                John H
