Help - Goodwill cabinets need a new design
  • Geoff Millar
    Originally posted by hangtentex View Post
    About the baffle. The original is 13 x 8, but it was set back in hex about 2 inches, with 2 other cut outs in front of it. There is no way to put it all the way on the outside, but I can get it right against the outside opening. Outside opening is 13 x 5. I can make the new baffle the same 13 x 5. Is this a good idea? It just seems bad to me to have so much wood in front of the drivers. Trying to get some new pictures of the baffle area, if that will help.
    Thanks - so if this mean that your baffle will 13" x 5", that will rather limit your woofer and driver choice, size-wise.
    Geoff
  • rpb
    (from the aforementioned thread)
    Chris Roemer
    01-22-2009, 01:29 AM
    Re: Xover design for DC200-8/DC28F-8
    Originally posted by dubeiram View Post
    Perhaps this is in the forum already and missed it thru my search... but does anybody have a xover design for the Dayton classic 8 inch woofer(DC200-8) and the DC28F-8 1 1/8 tweeter or the ND28F-6 neo tweeter... Also I see Dayton does not provide .frd or .zma for these speakers... does anyone have this info??
    Thanks guys
    Bud
    Here's mine. Put these in a 1.7 cf box, tuned to 30 Hz or a little lower using a 3"d REAR port. Length of 9" should be close.
    2nd order HP w/L-pad, positive polarity:
    5.6uF series cap, 0.50mH #20 shunt coil, SR = 4.7 ohms, PR = 7.5 ohms
    1st order LP w/Zobel:
    0.50mH #18 series coil, Zobel with 4 ohms and 47uF.
    The -070 silk dome WILL give the tweeter freqs. better dispersion so that they'll be more audible "up" where people's ears will be (instead of "beaming" 14 inches across the floor, which is what a small full-ranger will do). For an 8" woofer, the port you listed isn't large enough to reduce chuffing. I'd use a 3" (but a 2-1/2" will be OK if the end is generously flaired).
    Just for the sake of argument, the full ranger I suggested is comparable to the -070 tweeter at 15 degrees off axis, and doesn't t have a 5dB dip at 9k like the -070. That should easily be sufficient for anyone sitting 8' from the speakers.
    In addition, the grill cloth may reduce the highs on the top end as well. The filter I posted rolled off the highs, but it would be easy to get them back by changing one x-over part. (see picture)
    In this sim, the response is at 35 degrees vertical. (The top end would roll off some. This sim doesn't show driver roll-off, so I estimated it, and drew it in.) Since the x-over point is low, the mid-range hardly changes at all, and is still very smooth.
Name:	endtable off axis.jpg
    Chris Roemer
    Thanks guys
    Bud
  • hangtentex
    I didn't account for baffle dimensions, but this looks promising with 7 x-over parts.
    Honestly, I am humbled by all the help. Thank you so much for the interest, and all the thought put into this. But, this is way over my head. Is there a speakers for dummies version?
  • hangtentex
    Originally posted by Geoff Millar View Post
    What are the dimensions of the outside panels of the hexagon, please - it looks like the 'baffle' might be 13" high, but not sure about the width. You could then compare the dimensions with a design such as Chris Roemer posted above.
    NB Chris really knows his stuff and has helped many, many PETT members including me with their projects.
    It looks like an interesting and unusual project, good luck!
    Geoff.
  • Geoff Millar
    I might do a separate thread with baffle sizes, etc. I would just need to run the frds through response modeler, which I've only done twice, so, details, details.
    There's no resistors. Third order on woofer. (5mH or so would be most expensive part.) Third order high-pass with a .1mH to tame the top end.
    Thanks rpb
    Knowing 20% of not much about speaker and cabinet design, I really have no idea what effect the hexagonal cabinet will have on the design of the crossover or the sound of the speakers.
    Am still not sure of the baffle width (i.e. width of the outside panel of the hexagon), which also might affect driver layout and crossover design: hangtentex, do you have that measurement, please?
    Geoff
  • rpb
    Hi rpb,
    That sim looks rather promising: how do you find the parts values from that table, please?
    The PC83 looks like a very smooth driver with a few more dB than the VIFA TC9, which seems to be a popular driver for 8" two ways, and could work for those cabinets.
    Thanks
    Geoff
  • Geoff Millar
    Hi rpb,
    Thanks
    Geoff
  • rpb
  • rpb
    Yes, but then I would not get to buy drivers, and get practice building cool stuff. Which, was kind of the point of buying them in the first place!
    Ok, so how about this;
    1 - Dayton Audio DC200-8 8" Classic Woofer
    1 - Dayton Audio DC28F-8 1-1/8" Silk Dome Tweeter
    1 - Dayton Audio XO2W-2.5K 2-Way Speaker Crossover 2,500 Hz
    1 - Parts Express Speaker Cabinet Port Tube 1-3/8" ID Adjustable
    Cabinet is right at 2 cuft. I am going to remove the speaker mount and mount on a baffle just inside the front panel. And, of course, enclose the bottom.
    Comments?
    How about a Dayton DA215-8 paired with a Dayton PC83-8 crossed at 400hz? Looks cheap, and the x-over shouldn't be too hard.
  • Geoff Millar
    Comments?
    Others who know much more than I will be quick to advise you that pre-made crossovers can't work properly and will make your speaker sound below par. A custom-designed crossover will be essential, and there are several available for this driver combination, Chris Roemer's being one of them.
    Edit: here's the thread:
    http://techtalk.parts-express.com/fo...28f-8?t=209087
    I used Xsim to model the effect of that pre-made crossover on these drivers and the result is not good.
    Other PETT members will be able to suggest possible builds for that enclosure, but I haven't built anything with 8" woofers.
    Geoff
  • hangtentex
    Comments?
  • hangtentex
    I would be worried about liability if someone puts 200w to them, and burns down their house. My sister says I worry too much.
    My advice is to sell them as is for a smaller profit.
    Comments?
    Inline AGC Fuse Holder
    Put a 1A slow blow on them.
