Why so few higher powered Class D stereo amp boards?
As a mathematical approximation, when you increase the supply voltage by 50%, which is what you did going from 16 to 24 volts, you increase the available power output 125%, more than doubling. Of course this assumes the current availability also increases proportionally, no components are subjected to too much voltage, there are no heat related limitations, etc.
Paul
Originally posted by tomzarbo View PostSo I gave the amp 24v and ran it from the intended preamp. The difference between 16v and 24v is pretty substantial.
Louder and cleaner... it will work for sure. Now I'm even more impressed with that amp!
with bass heavy music playing for 5 or 6 min I only registered 90 degrees max on the heatsink. Seemed to be coasting heat wise.
Not to toot my own horn, but this radio is going to be pretty awesome if I do say so.
Thanks again all for the guidance.
TomZ
Originally posted by Paul K. View PostAs a mathematical approximation, when you increase the supply voltage by 50%, which is what you did going from 16 to 24 volts, you increase the available power output 125%, more than doubling. Of course this assumes the current availability also increases proportionally, no components are subjected to too much voltage, there are no heat related limitations, etc.
Paul
Yeah, it was much better, sounds like I wanted it to all along. Now to finish it up!
TomZ*Veneering curves, seams, using heat-lock iron on method *Trimming veneer & tips *Curved Sides glue-up video
Can anyone tell me is there any class D amplifier for guitears. I don't undestant much about amplifiers but I'm learnig how to play the quitar for a couple of years and I want to buy an amp for performances I'm going to give. I'll appreciate any advice
Originally posted by JoeCaWWW View PostCan anyone tell me is there any class D amplifier for guitears. I don't undestant much about amplifiers but I'm learnig how to play the quitar for a couple of years and I want to buy an amp for performances I'm going to give. I'll appreciate any advice
Originally posted by stephenmarklay View PostI am amazed at the distortion figures on some of these. There are a few that look reasonable but 10% THD at rated power is not idealElectronics engineer, woofer enthusiast, and musician.
Wogg Music
Originally posted by wogg View PostNone of them are 10% at normal levels, they just use that to show a higher rated power than what you can actually get cleanly.
https://www.parts-express.com/sure-e...board--320-301
• Power output (w/ 24 VDC power supply): 50W x 2 (6 ohms, THD 10%), 40W x 2 (8 ohms, THD 10%), 25W x 2 (6 ohms, THD 0.05%), 20W x 2 (8 ohms, THD 0.1%)
I am not impressed with a rating of 50x2 when 20w at 8ohms is 0.1% distortion.
I have a “normal” class D amp rated at 2x30 rated 0.005 at full power. That is what my expectations are.
That's just how some of the manufacturers list the boards - Sure always states the THD 10% and then THD 1%. I just ignore the 10% number.
You can find a Sure board that says it is a 50W board and PE may have a little amp using the same chip and call it a 15W amp because Sure is stating it with a THD 10% and PE is using THD .01%.
I pulled this one at random
I have a “normal” class D amp rated at 2x30 rated 0.005 at full power. That is what my expectations are.Electronics engineer, woofer enthusiast, and musician.
Wogg Music
Your best reference will be to lookup a data sheet on the chip used. Here's the TDA7492 used on that Sure board. With a 20V supply at 1kHz it's at 0.05% distortion right up to almost 20W where it increases dramatically (figure 20 page 18). Of course, that will depend primarily on the power supply voltage, and secondarily on the gain and board setup, but you'll get a much better idea of the real capability.
Much appreciated.
Thank you Wogg. really 20W is probably sufficient anyway. it is just the marketing that is a bit optimistic.
Much appreciated.
The major class D chips from TI, STmicro, etc, do a good job. When they're not driven into clipping expect < .3% THD at power. That said, power out is dependent on two things: power supply voltage and the speaker impedance (notwithstanding chip limitations). My rule of thumb is "clean" W rms = (PSV-1)2 / (2*SPR). That is based on physics and semiconductor losses for typical modules based on these chips.
Some examples:
24 V PS and 8 ohm speakers yields 33 W rms (66 W rms for 4 ohm speakers).
18 V PS and 8 ohm speakers yields 18 W rms (36 W rms for 4 ohm speakers).
12 V PS and 8 ohm speakers yields 7.5 W rms (15 W rms for 4 ohm speakers).
The "50 W x 2" ratings you may see reflect the chip's thermal limitation. But if you have a 24 V PS and 4 Ohm speakers you'll get 66 W rms (without a problem with music assuming the chip has a good heat sink and airflow). And that's worst case.
I recommend a 24 V PS for any of these amps. You don't have to use all the power the 24 V PS can give, but it provides a lot of headroom when needed.
I had been hesitant to go the full 24v because of the 'warnings' on the product page, even though you've even previously tried to asswage my fears Mike... but you're absolutely right... it seems that these amps can take it just fine.
I've been doing some near full-output temperature testing on the TDA7492 amp: https://www.parts-express.com/tda749...2x50w--320-606 and with the video player preamp faceplate feeding the source material it's peaking at around 120 or so degrees on the heatsink. That's pretty chill for a legit' amplifier producing real output. I like that little amp a lot more now.It's not until the very last three or four clicks on the preamp that it starts sounding harsh, but by then the woofers are going pretty much berserk at that point so it's a wash. Of course, I can get the preamp turned up to full and the ND91's are still alive, so the preamp determines a lot in this equation, but I think the amp is really doing a phenomenal job putting out some real power in a tiny size.
TomZ
Originally posted by Millstonemike View Post
As Wogg noted, forget the 10% THD watt ratings from the mfgs - marketing showmanship.
Some examples:
