Hi
I built a pair of small thors the woofers have corroded and I purchased some seas 18wnx001 woofers to replace. My original thought was to use the thor cabinets but I am ok with building new speakers using as many of the crossover components and the t25 tweeters. I have laid out possible crossover designs after reading several articles. I have a TM and an MTM crossover design and would like to know if they will work without hurting the tweeter.Will they work in the small thor cabinet with the crossover for the mtm ( removed one resistor) I also would like to build the cabinet with the drivers aligned raising the woofers on a thicker panel and would like to know if the crossover will work for that. If I build a new cabinet I would like to build a tall narrow floor stander. WAF Not sure of the role impedance plays but some of the articles made a point about it and not really sure if high impedance is bad I understand low impedance taxes the amp. I could only load 5 pics but the other impedance if quite similar. Thank You
