Testing baffle edge treatments for tweeter diffraction.
  • #46
    Originally posted by Chris Roemer View Post
    Most usually, the staggered distances to baffle edges will smooth out "on-axis" anomalies. A lot of designs where they're not staggered might not be that great on-axis, but will probably smooth out off-axis a bit.
    So, if staggered - you can toe 'em "in" (toward your listening position), but if they'e not, they often should be pointed straight out (perpendicular to the wall behind).
    If you want YOUR version to match the one you think you liked enough to build (from reviews), I'd NOT alter the placement of the drivers on the baffle.
    Very informative. I have read many reviews in the past where the reviewer mentions that a certain speaker works toed in etc. I had not even given thought to this.
    Thank you very much.
    • #47
      Originally posted by dlr View Post
      As far as I know, felt for diffraction control was first used on the LS3/5A and yes, it is effective. To what degree with the amount they used, I don't know. Thicker and broader is usually better with a point of diminishing returns. It was especially helpful for the LS3/5A since the front baffle was actually recessed to allow for a front grill. However, I have no doubt that more than they used would have improved the response, but as a commercial product, reducing cost is always a top consideration.
      dlr
      Thank you dlr. I have to look at wool and or other materials and what frequencies they are best may help attenuate. I have a fair amount of wool. I am dumb enough to try to make a "functional grill” using wool. I could cover all the baffle area with wool (covered in speaker cloth.)
      • #48
        Originally posted by DaveFred View Post
        Do you have drop box? The data file is 36 megs, I am happy to send it to you.
        I missed this the other day. No, I don't have that. 36M sounds like a lot for frd files (text only). Should be a lot smaller, especially when zipped. The text frd files are all that I want. I've never used REW, but I would expect that it provides a means to export frd (txt) files.
        Can you put a zip file into the Onedrive folder created by ergo?
        dlr
        Dave's Speaker Pages
        • #49
          REW stores all the measurements as a sweep (ie WAV or something like that internally) into the file, so it would include all necessary to process the IR... I could extract the FRD out of it. I do have REW and have used it to do that too.
          • #50
            Originally posted by ergo View Post
            Very interesting study DaveFred - Thank you for sharing.
            I created a OneDrive link with write access.
            https://1drv.ms/u/s!AvVPh3wl37Nzm4Qu...ktCxQ?e=YJUFZD
            Would be cool if you could copy the REW files there. Will make it easier to select the type of interest for further study.
            REW raw data file uploaded.
            • #51
              Thank you DaveFred. I've extracted the txt files out with space and tab delimited format and added a zip file to the same folder above. VituixCAD for example is able to open both without changes
              • #52
                One alternate view for each baffle type and offset used for each angle for clarity. 0deg highilighted
                • #53
                  Thanks for the additional data. Lots of good information here. Another interesting test would be to mount this particular tweeter (SB Acoustics SB26ST-C000-5) on an IEC-268-5 test baffle and run up the same set of curves. This would give us a better control reference against which to judge how the various baffle board choices affect performance.
                  SideTowers: http://techtalk.parts-express.com/fo...corundum-build
                  • #54
                    Thanks for posted the "txt" files. I used Omnimic and created normalized polar graphs of the square box and big bevel measurements. Clear improvement.
ID:	1427417 Click image for larger version
                    Tangband W6-sub
                    • #55
                      Any chance you could export those with FFT of maybe 500 instead of almost 54000? WinPCD could import that, but I have a program that doesn't re-map down, so working with 54000 data points is a problem. Plus, it's reading all of the files as well, so I'll have to modify it to re-sample and I don't know when I could get around to that. I suppose I should do that in any case. I'll have to review the code to see if I may also have a bug.
                      dlr
                      • #56
                        All of the files, space or tab delimited, seem to load and display OK in OmniMic.
                        I was curious as to how these curves would compare to the published specs on an IEC baffle, so I traced the data sheet curves into an FRD. My tracing skills are not the best, so please take the attached comparison curve with a grain of salt. The bulge and dip from 1-2kHz is obviously the baffle step, which flattens out on the IEC. It is interesting to note that all baffles seem to depress the 8-12kHz area compared to the IEC baffle.
Name:	On-axis comparison to IEC baffle.jpg
                        • #57
                          I think that I can re-map them myself. In the past I've used the free version of Praxis quite a bit for some post-processing, but it didn't seem to work in Win10 last I tried. I just tried it on my Win10 laptop, seems OK.
                          dlr
                          • #58
                            It's more likely that the raw driver varies from the published specs in that area. That kind of variance happens more often than not.
                            dlr
                            • #59
                              Click image for larger version  Name:	normalized-square-box.jpg Views:	39 Size:	59.3 KB ID:	1427417
                              For what it's worth, here's the result of a diffraction simulator I wrote. I can't do arbitrary shapes, but I think I can do roundovers and square edges. My square edge result is attached. I didn't import the frequency response or anything, so my 1" tweeter has perfectly flat on axis response. Still, I see a lot of similarity. I suspect that either I'm over-estimating the dispersion of the tweeter, or else some detail has been missed in using measurements taken every 15 degrees. More measurements would be interesting.
                              • #60
                                Very impressive work, dude!
                                I'm not competent to discuss the mathematics of your simulation, but I think some other folks here can get into deep discusssions.
                                The most sophisticated software I've seen is "the edge", you might want to compare your results with those simulations.
                                Tangband W6-sub
