New Project, Tube Amp Friendly
  • New Project, Tube Amp Friendly
    I have a friend who wants to build something.
    He is running a pair of tube monoblocks and is a true music lover. He has a Linn LP-12 and has about 5000 records. All vinyl listening!
    Budget is maybe $700 for drivers alone.
    Looking for something fairly efficient and can't have wild impedance dips. A fairly benign 8 ohm load would be preferred.
    I am thinking
    2 x RS225-4 (in series), maybe in a T-line
    1 x PRV 5MR450-8 5" (I've heard great things about this one)
    tweeter? your suggestions?
    US$1000 for a kit would be OK, but I am leaning toward suggesting something custom.
    I have suggested the Elsinore project, and that is certainly a possibility but we aren't in any great hurry.
    Hard to beat open-baffle for tube amps :
    https://www.lii-audio.com/index.php/...-f-15-in-pair/
      Troel's original Seas 3 way classic. 90 db, tube friendly. there are now several 3 way classic designs. If your friends monoblocks are 3 watts, probably not right for him.
      SEAS-3-Way-Classic
      3WClassic-Andy-US
        SEAS-3-Way-Classic
        3WClassic-Andy-US
        The Seas 3 way classic looks like a very viable option.
          Open baffle requires tremendous power in the bass. Maybe not appropriate for anything but high-power amps.
          Francis
            Depending on the size of the baffle .
              Well, ok. If the driver is in a large room-sized wall, no problem.
              Francis
                I don't think the 2x RS woofers will give you enough sensitivity for a small(ish) tube amps.
                Dayton does have some pro and semi pro woofers that are very reasonably priced, and may work for your needs and budget.
                for 5-6 inch mids, I really like some of the Beyma drivers, but the better ones may exceed budget.
                Lot's of tweeters would fit, so you might be able to provide a solution.
                Tangband W6-sub
                  His monoblocks are 4xEL34 each so power shouldn't be an issue. I am guessing 70 or 80 watts?
                  I have almost talked myself into building a pair with
                  2 x RS225 per side + 1 PRV 5" + HiVi 1.3 tweeter
                    4 EL34s is plenty of power to run a normal speaker. The thing that will make the tube amp happy is a highish impedance that is relatively flat with good flat impedance phase. This is an example of a tube friendly impedance:
                      Check out something like the HT10 or HT12 at DiySoundgroup for a higher sensitivity, tube friendly kit.
                        You could also use that driver budget to buy a bunch of little full rangers for an array.
                          We purchased a Travelers kit (essentially an updated Finalist). I found out his amps are 70W and doesn't listen THAT loud so I have high expectations. We have a set of Finalists here (along with Kairos, Stances, Bagby RS180 MTM, others)
