DATS v3 - rough impedance sweeps
  • #16
    Different issue . ( @ least on WT3 )
    Won ' t calibrate @ all with wrong settings .....
    • #17
      Originally posted by billfitzmaurice View Post
      I can't say why it's so rough, but so long as you see the peaks and valley it's telling you what you want to know.
      It's "not" telling me what I want to know - since I have to guess at what value is correct unfortunately.
      • #18
        Originally posted by PWR RYD View Post
        That is not a "less smoothing" issue. It is clearly noise, caused by poor signal to noise ratio, improperly set gains, or a cold solder joint/bad wire connection.
        Inside the WT3 itself??
        • #19
          Originally posted by Chris Roemer View Post
          (Even though it LOOKs like the orig. "WT3 Beta Testers" forum has been culled ...)
          I'm pretty sure that I contacted John re: one of the (WT2? / WT3?) "upgrades" which suffered from this exact same problem, and he said it was an easy fix, and he FIXED it !
          Fixed it how?? Did you have to send it back??
          • #20
            Possibly.
            Craig
            • #21
              It ended up just being a software "adjustment".
              • #22
                Chris and n8skow, did you ever find out what gave the edgy impedance curves with DATS V3? I see the same problem with my setup and have not been able to fix it.
                What was the SW adjustment?
                I have upgraded from V2 to V3 and they give very different results. All standard settings checked, like 44/16, dual channel aso.
                All input appreciated
                Kind regards
                //Rob
                • #23
                  I've owned the DATS v1, v2, and now (after waiting 4 months) the v3.
                  I immediately noticed - when doing an impedance sweep to examine the tuning of a given enclosure - Z is all over the place. What was a smooth curve in v1 and v2 is now a rough mountain range in v3. What gives?
                  It looks like the test signal is too weak. Make sure the Windows playback level for DATS is at maximum and also make sure the Record Level is at maximum at the Sound control panel. Finally make sure the sweep level is set at maximum (+10 dBu) at the signal generator page. Here is what it should look like:
Name:	sweep level.jpg
                  Best Regards,
                  John
                  John L. Murphy
                  Physicist/Audio Engineer
                  True Audio
                  • #24
                    Originally posted by RABrown View Post
                    I have a related question of I could jump into your thread. After an upgrade to Windows 10 my DATA v2 no longer works. Is v2 supposed to work with 10? Thanks!
                    Yes, it works fin e with Windows 10. But Microsoft has now enabled "microphone privacy" so you have the give permission to apps to use the "microphone" at: Settings/Privacy/Microphone.
                    Best Regards,
                    John
                    John L. Murphy
                    True Audio
                    • #25
                      No issue here on a Dell laptop with Windows 10 Enterprise running DATS v3 with latest software. Woofer and Tweeter impedance sweeps are smooth (apart from environment or reflection induced ripples)
