Corian: Can I use a forstner bit?
  • Corian: Can I use a forstner bit?
    I have routed Corian successfully buti it is pretty messy. I drilled it yesterday and also recessed the holes ok too. I did see that if I go to fast it will chip the edges of the hole. Slow works better.
    But I have not used a forester bit to know if it is something that has a clean enough cut.
    I could probably use the forstner bit on 3/4 ply to act as a guide for a template bit.
    Thoughts?
    I'm thinking a Forstner bit with a 'wave edge' would be your best bet in controlling edge chipping. I have not attempted this however.
      forstner bits have a grab type cut. You will not get control with them as they bite in . Id get a end mill and mount it in the router and run it on slow speed. That also corian does not hold threads and will need inserts or through bolts and easy on the torque ! Did you use corian gun to glue it?
        I use Irwin fostener bits on Corian all the time. As with any material, put a scrap board under it. No issues whatsoever
          I've had no issue with Corian holding threads. Nor any problem drilling with conventional bits or fostener. Same with routing. The only "issue" was that an 1/8" hole was 1/8"! Made getting my router pin a bit of a hassle lol.
            Ok cool! I will take my tie and practice on scraps. Much obliged
