Tenshi Zaph Audio woofer and SB Acoustics tweeter
  • Tenshi Zaph Audio woofer and SB Acoustics tweeter
    Tenshi is Japanese for angel and as these are for my niece, aptly named. I build speakers for each of my nieces and nephews for graduation presents. They pick the color scheme and I do the rest. This time she chose an aqua color and glitter lol
    This time, I chose the Zaph Audio ZA14W08 woofer and SB Acoustics Sb26stnc tweeter. Both were already in my inventory of components. I chose an enclosure size that is large enough for bass extension to at least 60hz but still small enough for a desk or bookshelf. To that end I also chose to keep bsc to about 4db vs a more typical 6db.
    The enclosures are constructed of 1/2" Baltic birch ply with a side to side brace. The measure in at 11"H 7.5"W 9"D for a volume of 0.3 cf, 8.5L and with a 1.5" ID port x 3.25" L for an Fb of 60hz. DATS measurements confirmed the tuning to be dead on. F3 is about 55hz iirc
    The crossover is straightforward and very simple. 5 components and a crossover point of about 1.9khz. For more bsc, a 3mh inductor and 7ohm resistor could be used. Note there is a mistake and on the schematic as the tweeter should be normal polarity.
    On to the pics!
    The crossover is straightforward and very simple. 5 components and a crossover point of about 1.9khz. For more bsc, a 3mh inductor and 7ohm resistor could be used. Note there is a matistake and on the schematic as the tweeter should be normal polarity.
    On to the pics!
    That’s very cool tradition. I love the color. This will be the envy of her friends. I bet they sound fantastic.
      sweet....what sort of prep do you need to do to get a finish like that with ply?
        I sand to 220grit using a block wider than the panels. Then multiple coats of primer, sanding between coats. Then spray applying 2 light coats at a time. After each double coat, allow cure time for a few hours.
        The finish here is far from perfect. However I am also applying layers of glitter spray with seal coats in between. Once cured, I will wet sand to 1000grit and apply 2 more coats of seal.
          Labor of love, for sure.
          The smile on her face will be worth it . . .
            Do you use high fill auto primer or something else?
              That's really nice for rattlecan paint. Gold glitter?
                Very cool! Bet they will sound great! Where do you get the spade connectors for the crossover boards?
                  Yes, high build automotive primer.
                  Glitter is in layers. gold, silver, and black.
                  The terminals are from Meniscus.
                    Thank you!
                      Nicely done, those will look very cool when they are done. That Zaph woofer gets a lot of praise for its low distortion and you have used the SB tweets quite a few times, so I'm sure this will sound VERY nice.
                        Thanks for that Scott. I actually wasn't sure i would like the Zaph woofer. The other titim I have heard it, I didn't care for it as much. Might have been a product of the crossover, placement, etc. but I decidedly to give it a try and am really liking what it is capable of here
                          Few more pics. 2 coats of glitter and 4 coats of clear pearl finish.
