Small Full-Range Drivers for Line Arrays - MCLA
  • #16
    Originally posted by jhollander View Post
    China, OK. Europe maybe not
    Okay then. I'll spray everything with 91% isopropanol before shipping. But you might want to douse the box before opening it. The mail is second only to money regarding germiness.🙂
    "We are just statistics, born to consume resources."
    ~Horace~, 65-8 BC
    • #17
      Yeah but the virus doesn't last long on paper and cardboard, the slow boat will be long enough until usps touches them
      John H
      • #18
        Yup, but if the box uses clear packing tape, that would qualify as 'plastic' and that surface holds the virus for quite a bit longer... not slow boat from China longer... but it's worth spraying the box and inner contents before considering it 'safe' for touching as a clean item. Anything a shipper touches would have to be considered 'potentially contaminated' as you mentioned.
        TomZ
        • #19
          TomZ
          Yes, better safe than sorry. Two of the dirtiest things on this planet are cash and mail plus other deliveries. It only takes one microbe.
          ~Horace~, 65-8 BC
          • #20
            They arrived today. I thoroughly wiped down the outside of the box with 91% isopropanol, then opened the box and tossed the foam padding and washed my hands. I can't do much else other than let them sit for three weeks. I'd rather not boil the drivers or soak them in alcohol.😁 These measure precisely 1.75 inches in diameter. Sorry for the dust in the photos.
            ~Horace~, 65-8 BC
            • #21
              what was the intention with these lil fellas? as in do you have a box design already planned for them?
              how'd you get them for 2 fiddy each? that site you linked was 3x that.....ps i havent googled and im sure a huge chinese online site would probably have them.
              • #22
                Those will make a good looking array. If you have a box plan I can attempt to duplicate the baffle for the measurements
                John H
                • #23
                  this may be a stupid question, but is a line array always vertical?
                  • #24
                    Typically, but there have been some cool horizontal center channel arrays.
                    John H
                    • #25
                      I'll be using them in narrow eight feet tall floor-to-ceiling corner line arrays similar to Murphy's 'MCLA'. I can't afford to buy all those pricier drivers so I'm substituting these. I would have preferred slightly larger drivers but these will do nicely, I hope.
                      I bought them from a Chinese eBay seller and negotiated the price as leveraged by the quantity I purchased.
                      ~Horace~, 65-8 BC
                      • #26
                        I need to keep this build simple and inexpensive. These also need to be very narrow due to very limited space by a doorway. My current thought is a right triangle with the drivers mounted on the hypotenuse, though I might opt for Murphy's truncated square design. See image below.
                        I'm uncertain regarding how to implement the center channel. Obviously, it won't be corner loaded. Also, I don't know whether it should be vertically or horizontally positioned. I'm thinking vertical orientation will best integrate with the mains.
                        Click image for larger version  Name:	mcla.jpg Views:	0 Size:	10.6 KB ID:	1435348
                        OR... I might consider a 1/2 or 3/4 round tube design so they can be adjusted to any angle.
                        ~Horace~, 65-8 BC
                        • #27
                          IMO a simple rectangular box would be good that way you can move them anywhere or adjust the toe in to any angle. I think the limiting factor on the center channel will be the number of drivers needed to hit the spl target.
                          John H
                          • #28
                            I can't remember now but I think, for the MCLA concept to work properly, the mains must be pushed all the way to the corners of the room, not just close to them. I guess a simple square tube could work though. I was thinking the same thing about center channel SPL, especially in the bass range. I was/am thinking of doubling the number of drivers for the center channel and EQ-ing it a bit different than the mains. I inquired about this in another post but was told it wasn't necessary and to no advantage. I just don't know.
                            ~Horace~, 65-8 BC
                            • #29
                              Does your doorway have a door that closes or is it open all the time? I would think it would affect the response on that side of the room quite a bit if it's open.
                              The idea of a tubular enclosure seems like if would be pretty flexible to position angle-wise. I also recall from reading the thread, that the enclosure should be pushed almost right to the corners if possible like you said, and PVC or ABS is only 1/4" thick or so, so you could get really close with that....
                              But, I don't think it would matter if it were a rectangular enclosure and you angle the front to a good position, then created baffle extensions that went from the cabinet to the walls out of a similar looking material. I think the smoother that transition is, the better.
                              Take pictures please, this is interesting! Reminds me of Darren Kuzma's Kuze3201 speaker from way back....
Name:	Kuze arrays.jpg
                              Here's the link to it... it may give you some inspiration on cabinet construction: http://projectgallery.parts-express....01-line-array/
                              TomZ
                              • #30
                                Here is a chart of standard Schedule 40 PVC dimensions
