Small Full-Range Drivers for Line Arrays - MCLA
  • #31
    Does your doorway have a door that closes or is it open all the time? I would think it would affect the response on that side of the room quite a bit if it's open.
    The idea of a tubular enclosure seems like if would be pretty flexible to position angle-wise. I also recall from reading the thread, that the enclosure should be pushed almost right to the corners if possible like you said, and PVC or ABS is only 1/4" thick or so, so you could get really close with that....
    But, I don't think it would matter if it were a rectangular enclosure and you angle the front to a good position, then created baffle extensions that went from the cabinet to the walls out of a similar looking material. I think the smoother that transition is, the better.
    Take pictures please, this is interesting! Reminds me of Darren Kuzma's Kuze3201 speaker from way back....
    Click image for larger version  Name:	Kuze arrays.jpg Views:	0 Size:	14.1 KB ID:	1435355
    Here's the link to it... it may give you some inspiration on cabinet construction: http://projectgallery.parts-express....01-line-array/
    TomZ
    I'm sure you're right about an open doorway affecting frequency response, etc. There is a door. I like the link you posted. Thank you. I'm thinking Sonotube would work too.
    "We are just statistics, born to consume resources."
    ~Horace~, 65-8 BC
    • #32
      Originally posted by randyohoh View Post
      Here is a chart of standard Schedule 40 PVC dimensions
      Very helpful. Thank you.
      ~Horace~, 65-8 BC
      • #33
        The corner mounting is going to adjust the space to 1/2 pi so you can pick of some SPL. The baffle response will also change. Are you DSPing?
        John H
        • #34
          Thank you. True, and if I remember correctly corner placement also boosts bass below 200 Hz or so. Yes, I'm using DSP.
          I'll probably split each eight-foot tower into 4x two-foot sections and amplify each section separately. Not only will this make transport easy but I can also amplify and time align each section individually.
          ~Horace~, 65-8 BC
          • #35
            It's been six days since these arrived and I'm not coughing or sneezing.😁
            ~Horace~, 65-8 BC
            • #36
              Asymptomatic?
              John H
              • #37
                Asymptomatic?
                So far 🙂
                ~Horace~, 65-8 BC
                • #38
                  I'm finding conflicting information regarding at what frequency corner loading begins to boost low frequencies. I'm seeing everything from 60Hz to 200Hz. I'm guessing it's a bit lower with full floor-to-ceiling arrays but I don't know. Of course, this will greatly affect how these drivers will be used.
                  Can someone direct me to this information?
                  ~Horace~, 65-8 BC
                  • #39
                    It depends on the proximity to the walls and floors. I would use Jeff Baby's Diffraction and Boundary Simulator. http://audio.claub.net/software/jbabgy/BDBS.html
                    For multiple stacked drivers I have used the average of the vertical height for the location above the floor
                    John H
                    • #40
                      Thank you for that. It seems there's a 2 dB dip at 100 Hz followed by an arced rise below that. SPL doesn't recover and begin to add gain until 70 Hz and below. I'm not quite sure what to do at this point. Will the single centered driver behave the same as a floor-to-ceiling line array regarding corner loaded gain?
                      ~Horace~, 65-8 BC
                      • #41
                        For the purpose of the spread sheet that's the best estimate we can use. A 2 dB dip is not audible. Again this are just estimates, if you can measure you would get the actual result plus the speaker's FR response.
                        John H
                        • #42
                          Right, but I was hoping for a 12 dB/octave rise below driver resonance down to 80 Hz or so. At this time, I have no measurement equipment. I had to let it all go years ago. I'll acquire more eventually but after this driver purchase I'm really feeling a fiscal squeeze.
                          ~Horace~, 65-8 BC
                          • #43
                            I'm not dead yet so I guess I don't have the virus. I've not been out so I can't have contracted it. Should I send these drivers to you or wait? Whenever you're ready, PM me your address. I'll reciprocate.
                            ~Horace~, 65-8 BC
                            • #44
                              Model the speaker in HornResp, which has the option for 1/8 space (corner) loading.
                              www.billfitzmaurice.com
                              • #45
                                I'm not dead yet.
                                I saw that movie. PM on it's way
                                John H
