1.75” port options
  • 1.75” port options
    My sub build looks like a 1.75” port would be about ideal. 2” is just too long and 1.5” too much port velocity. The problem is that I still need upwards of 13” which requires one elbow.
    Are they any options out there that I can get the length need using an elbow?
    I also occured to me that maybe I could use a flexible hose? Would that work? If so it would probably work fit wise.
    Thank you all
    I was just contemplating something like this over the weekend. I thought about a piece of flexible exhaust pipe but discarded the idea because it's not smooth inside. What about going to your local exhaust shop and getting them to bend a solid piece of pipe? Have them bend it so both sides of the bend are overlength so it can be cut down and tuned.
      You have a source for 1.75" pipe? Unusual size..
        Never tried it, but a sturdy thick-wall rubber hose might work fine.
        Francis
          1 3/4 id is 1 7/8" od. in 16 gauge mild steel. Should be able to get a piece without a problem. If the exhaust shop doesn't have it try a place that builds headers.
            Ports are usually longer than they need to be due to varying things. If you install it close to an inside wall, for example, or because we generally underestimate how much air space is consumed by drivers, crossovers, stuffing, braces. My personal rule of thumb is to trim 10% or so off calculated length. More if I anticipate effective lengthening of the port due to panel proximity.
            Fkex hose will work, I suggest coating it liberally with epoxy or other hardening agents though.
              Oh, and the port tube itself consumes considerable internal volume.
                Sorry, one more comment. The 2" will likely work because of the comments above. Depending on gross volume of the enclosure, that is.
                  Thank you everyone. When I mentioned flexible hose I was thinking of reinforced PVC. I now my Kef LS50 has a flexible section that they used to deter port resonance. So I figured maybe it would work.
                  Thank you Johnyrichards, I am going to play with Winisd and see how slight differences (10%) make and also vary the box volume a little in the modeling to make sure nothing wonky happens.
                  Much appreciated.
Name:	ABS Dimensions.JPG
                    The actual inner dimension of ABS plastic 1.5" pipe is really 1.61" or so if that helps any.
                    TomZ
                    And Home Depot has elbows. All you need now is decent flared end pieces.
                    Francis
                      Takes some practice, but a heat gun and wine bottle can be used to flare pvc pipe.
                      • stephenmarklay
                        stephenmarklay commented
                        Editing a comment
                        I think I will play with this.
                      You can also epoxy the vent so it's flush with the front (or rear) of the cabinet, and then use a roundover bit in the router to create the radius that way. I usually just 'ease' the inside exit of the tube with some coarse sandpaper.
                      TomZ
                        Two 1-1/4" pipes have almost the same area as one 1-3/4". 2.45 square inches vs. 2.4 square inches.
                          If you cannot find the size in pvc, water or drain, try grey electrical conduit.
