Goldwood Subwoofer Bargain
  • Goldwood Subwoofer Bargain
    Just ran across this
    https://www.parts-express.com/goldwo...-coil--299-524
    Looks like it can reach pretty low in a not so big vented box. Any cause for concerns?
    // WWW.JONCON.NET
    // SPEEDSTERS - Concrete over 3D Print Build Thread
    I think Goldwood tends to exaggerate some specs or provide inaccurate ones in some situations, but I could be wrong about this....mostly I'd recommend thinking of them as 40-60watt woofers rather than their claimed 400watt peak both for voicecoil melting reasons over longer playing and because I'm pretty sure giving them 120+watts of deep bass for even short bursts could cause mechanical failure.
    The price makes them look like a fun project if you're fine with the ~2ft+cu box size and either 2ohm or 8ohm load on your amp.
      I think for the price they would be fun to mess around with.
      Two of them wired in series (4 ohm) for under $18 in a isobaric clamshell configuration vented might perform decently in a reasonably sized box.
      Efficiency is pretty high, you could experiment with adding some weight for mass loading...
      ...just pondering of course.
      TomZ
        Thinking the same as Tom.
        Looks like another candidate for a cheap a$$ ISO sub, like the GRS 10" but even cheaper. A clam shell could cut that recommended box in half for the same F3, 26Hz in a 1.3 cu ft sounds nice.
        Wogg Music
          Not an expert in WinISD so no guarantees this is accurate, but this is the transfer function for sealed 1.4 cubic feet and vented 2.6 cf (per PE's recommendations). One driver, not two.
          I believe peak power is usually a technical spec on when something bad happens (voicecoil melts or something), these slightly exceed x-max with 25 watts.
          Maybe wire 2 in series with a PE 70 watt or 100 watt plate amp...
            Thanks guys. I was thinking this was a good candidate for messing around with. I have an old Dayton DTA100 stereo amp that I thought could power two of these fed with a low pass sub signal from a receiver.
            // WWW.JONCON.NET
              I bought 2 just to mess around. I think I will do an isobaric cone to cone config in a 8" concrete form and stick it under the couch. Super cheap and hope it works out. Question regarding the wattage. I gutted an old sub for its amplifier. There are no obvious markings on it but it seems fairly beefy. Is there a way to determine its power output?
              // WWW.JONCON.NET
                Strap a known resistance across the speaker leads and measure the voltage across the load. Then you can approximate the power.
                  Guy could build a pretty inexpensive distributed bass system using these. Two isobaric loaded per cabinet, eight cabinets, cheap pro audio amp. 16 drivers, some particle board shelving from Menards, any number of Behringer options for watts.
                    For the vented calc, do you know what size port is being used?
                    // WWW.JONCON.NET
                      The 2.6 cubic feet was for one driver, so if you doubled them up then the tuning would change.
                      2.0" diameter x 3.75" long (chuffing might be a problem here)
                      2.5" x 6.25" or
                      3.0" x 9.5"
                      Note, I'm just getting results from WinISD but don't know if this is a particularly good box model. Others are much more experienced than me and hopefully will chime in if there are obvious better alternative box options.
                        Has anyone purchased/received any of these and taken T/S measurements yet? It's hard for me to get too excited about gold wood products, especially buyout gold wood products LOL.
                        Craig
                          I have to wonder how good the quality control is. So, even if one example measures well, do the rest?
                          Francis
                            Agreed.
                            Craig
                              You guys are taking all the fun out of wild speculation over potentially dubious published T/S parameters
                              Wogg Music
