Hi Folks,
I'm doing some testing on a pair of speakers that I built for a relative a LONG time ago that encountered some kind of catastrophic failure (guessing the power amp fried). The scanspeak woofers are definitely gone and I have already tracked down a used pair of replacements. I thought we also lost the tweeters as well but the first one is actually reading about 4.6ohms so I think may be ok. What's strange is that I seemed to be getting very reduced output from it. So this prompted me to disassemble the crossovers figuring maybe there was some issue there... these are, after all, about 20 somewhat years old.
Pretty much all of the caps are reading high by about 10%. Not great but essentially in spec (albeit on the edge) for these axon caps -- not likely a huge issue. The resistors are all fine. I don't believe I can check the actual inductance of the inductors but I don't seem to be getting much resistance. These are solen air core inductors. All 3 of them have continuity and are reading about 0.2ish ohms of resistance but the reading doesn't seem to be that stable. For example the smallest one (0.25mh) settles at about 0 resistance. It seems highly unlikely that the inductors would fail in the first place but just hoping to make sure. I'm guessing this is a super simple question so apologies in advance!
thank you!
edit: nevermind on the resistance question for the inductors, I just found the spec page for them on wisconsin vendor's site and the resistance is lower than I expected. The 0.22 one is spec'd at 0.08ohms so mine would be even lower than that... probably ok. Leaving the post up just in case anyone has suggestions for other tests that I should run.
thank you!
