Using Seas L22rn4x/p as subwoofer
  • Using Seas L22rn4x/p as subwoofer
    Im new to speaker building. I have a Seas L22rn4x/p woofer. I was wandering if it might work as a moderate powered subwoofer. I have a Dayton Audio sa 100 amp. I thinking maybe a 1.1 to 1.2 cf box ported. The port I have is 2.5 inches. Im thinking that it will stay in x max limits with that power in that size of box. I dont have any modeling programs. Thanks in advance
    Do yourself a favor and download winisd. It’s really easy to use.
    http://www.linearteam.org/
      That should work OK. F3 in the mid 30s when tuned to the low 30s (10" -11" long).
      I'd consider 2-1/2"id the min. for an 8" woofer (and I'd recommend a generous roundover on the exit, AND aiming the exit away from your listening position - like out the back).
      I've got 2 datasets on that driver; one shows Xmax as +/-7mm, the other shows 14mm?
      WinISD is FREE ( linearteam.org ) and fun (but won't run on a Mac). -sc
        The 14 mm Xmax spec is more than likely meant to be peak to peak.
        Paul
          Thanks for the link
            I tend to listen to, not heavy bass content music
              this is a very nice woofer. you are right on with box size. with a 2.5 inch port about 7 - 8 inches long you will be in the low 30's. i would not tune this driver to the lowest frequencies you can get. one thing to remember, this is not a subwoofer, this is a woofer. i do not think a 100 watt plate amp is your best choice either. just some things to think about.
              p.s. linear travel is 7 mm p to p ( peak to peak), that means 14 mm travel. x max is around 20 mm.
              craigk
                I made a 1.2 cf box , and installed 3inch 10 in long ports. It surely isnt the best tuning but she is rolling some nice bass. I didnt put the sa 100 in the box. I left it seperate in case it fails I aleast can look alternative methods to drive if the amp pukes.. THE SA 100 drives nice at 1/4 gain. Especially at 75 watt for an 8 ohm load. I also have it hooked to a LFE y,ed out
                  I used my second Seas and built another box like my first. Still driven by the Dayton sa 100 wired in parallel. I like the bass quite impressive. I had a Jl AUDIO 12w0v3 with a Dayton spa 250 in a 1.80 cuf box. The bass was good but not nearly as clean or the sq the Seas can do.
