KAB-250v3 standby whine
  • KAB-250v3 standby whine
    I've got the KAB-250v3 and DSPB-100 connected to create a 2.1 system, but there's significant whine / hum on standby.
    I bought the power supply from Parts Express and it makes no difference over a cheap 24V/5A Chinese unit I already had laying around.
    P/E refunded and sent me new amps after I told them all the troubleshooting I went through, but they make the same exact while / hum.
    The power supply doesn't have a ground, so I can't try doing any of the ground loop fixes, like with a set of diodes inline.
    Here's a recording of it in case that helps diagnose it: https://photos.google.com/share/AF1Q...ZfWXRKcWJiWmhB
    This is the last thing to dial in for this system and I'd really like to get it resolved before giving up on it and going a different route for powering it.
    Thanks for any help!
    -Josh
    I can't hear the wine in your photo-video. So my first guess is ground loop. That would be a fairly low note - 60 Hz whine.
      I don't think that's a defect, but it isn't really a feature either. When the signal stops via YouTube on the OSFA I just built, there is a pitch present until signal resumes. This is via bluetooth mainly.
        I tried frequency matching it and it's around 120hz.
        The whine is pretty audible with headphones on listening to the video.
        I'll try using the 3.5mm jack as the source and see if it has the same issue.
        Interestingly, I can also hear a noise that coincides with the bluetooth light flashing when trying to pair.
        Thanks for the feedback. I might just send it all back if I can't sort it since it's for a set a friend had me build and he'd go nuts with that whine.
          In the U.S. that's a harmonic of our (60Hz) AC line frequency.
            Since you mentioned you're using it over bluetooth, I'll add that I've had some bluetooth sources that are a LOT worse than others. If you have a chance to test other sources that might be worth checking. Though I'm guessing your phone is a common source and I don't think I've noticed much problems from my phone over BT. Mainly it's been a specialty little BT-sender/converter that I've used to make older devices send wireless that seems to always make the KAB (a 230 in my case) whistle pretty noticeably.
            Or maybe it might it be as simple as shielding the little amp with a metal case (aside from the BT antenna of course)?
            My first 2way build
              I whant to use the same setup in a portable bluetooth speaker... You can hear de noise pretty good, I assume it's the Kab 250? You can try the kab-230... I read somewhere on the internet that the kab-250 had to much gain so they chose the 230.( don't know much about electronics but it's some information about it 😅). Maybe it's fixable with the dspb board settings..
                I thought of that, too, as I was writing out the frequency.
                I'm going to see if I can use a power conditioner to see if it has any effect.
                I've tried my laptop and iPhone 6S and they both produce the same sound through BT, so my guess is it's not the source since they don't create any other hum like that with other BT speakers I have.
                That's an interesting theory.
                I've actually had two different setups and they both have the same hum.
                The first was the KAB250v3 + DSPB 100 and the second one is the opposite with the DSPB250v3 + KAB 100.
                The 100 units also hum through the sub in both cases.
                I'm going to try the 3.5mm input and see if the hum disappears.
                But, that means the BT won't be paired and that leaves it in pairing mode, which causes a secondary hum when the light goes on and off.
                  I'm curious about that to, strange thing about the bluetooth and the 3.5 plug. That means that you can't use the 3.5 because the unconnected bluetooth will hum, so why they attached it on the board? 🤔😁
                    Maybe because of this?
