Help with first time build.
  • Help with first time build.
    I just recently caught the bug, so I'm a new member. I would like some input/advice on building a new enclosure for my Dayton 10 inch classic. It's currently in an old 1 cubic ft enclosure that housed a jvc sub and running off of the subwoofer channel from a Logitech z5300 amplifier (100w). However I recently built a tda 8954 class d mono amplifier which should at least double that, hopefully more, and think I need a more sturdy and efficient enclosure for my home theatre. I'm leaning toward a slot port enclosure, but since I've never built on I'm asking for any knowledge or help I can aquire.
    Two suggestions:
    First, post this in the Tech Talk forum, you'll get more traffic as this part is intended for completed projects.
    Second, look up WinISD and familiarize yourself with how the T/S parameters work and how to model a woofer box. Every woofer has a range of cabinets it will work well in, and you can play with a box model to determine what you want.
    Welcome to the forum!
    Wogg Music
      Originally posted by identicalseparate
      Did you know that you can now buy essay online? Its good news right!
      The best news a spambot could offer. The pidgin English is a nice touch.
      Francis
        If you mean the Dayton Audio DC250-8 10" Classic Woofer ... you have a bit of a mismatch.
        First, your woofer is 8 ohms. The Logitech system was likely powering a 4 ohm subwoofer so you're really only getting half the rated power into the 8 ohm Dayton.
        Second, look at the PE page for the woofer. It gives recommended box sizes with the associated F3 frequency (e.g., a low end frequency rating). For a sealed box, the F3 is 55 Hz, hardly HT sub performance. A ported box delivers an F3 of 29 Hz. However you need a very large ported box ~4.5 ft3.
        Lastly, the Dayton's linear excursion (Xmax) is only 4.5 mm. Hardly HT sub capable. It will likely bottom out well short of max volumes.
        If your planning a small room HT, you can likely find an 8 ohm subwoofer for the original Logitech box. If you really want to go big, look for an entirely new subwoofer/box combo.
