I have been experimenting with the Morel CAW538 in a 0.25 cu. ft. cabinet (8" wide) tuned to 53Hz for two different projects. One with the Morel CAT308 tweeter and the other with the Fountek NeoX 3.0 tweeter. The results have been very good with a textbook 8 ohm 2.1 KHz Linkwitz/Riley 2nd order crossover. I have also been using an 8ohm variable L-pad (potentiometer) for tweeter attenuation. I have also been using a textbook Zobel network of an 11 microfarad capacitor with a 6.5 ohm resistor. I have limited the BSC to -3db as greater attenuation seems to make the CAW538 dull and lifeless.
The results have been excellent but I would like to try a custom crossovers for both projects before beginning the build process. I would also like to convert the variable L-pad to a fixed voltage divider, however, I do not want to over attenuate the tweeter(s) and the impact of the added resistance on the crossover is very difficult to calculate. My Mac is too old (for Boot Camp etc.) to run windows and it seems like most crossover design software is developed for Windows only. Would anyone be willing to model a crossover for either or both of these projects for me? Thank you in advance for your help!
