Sprite in a Can
  • Sprite in a Can
    I'm adapting Paul Carmody's Sprite speaker into a Fat 50 ammo can. The can is lined with .25 MDF and is divided into two separate speaker chambers of just over 4 liters. If I fit the 5.75 long port tubes from front to rear in the box the opening for the port tube will only be about an inch from the rear or front wall depending on orientation. If I run them from the bottom to the top it gains another 1.5 inches of clearance from the port end. Does it make a big difference how far the port is away from the inner wall of the enclosure?
    "1 diameter" is the suggested ROT.
      Originally posted by chris roemer View Post
      "1 diameter" is the suggested rot.
      thanx!
