Originally posted by unclejunebug
View Post
Don't lean on my rough estimate too much though...probably safer to assume somewhere between 12-16mm Xmech and either leave the amp about 3db down from full if you'll be blasting movie sound-effects or think about adding a small 0.5uF-0.75uF capacitor/s to the line level inputs (they're listed as 10.4Kohm in the manual, so I think a cap value around 0.5-0.75uF should give a nice bit of protection for bass under 30hz-20hz). Because a Y splitter/combiner RCA (or stereo sub line-level output from your reciever) is recommended for the SA70, I'm not sure if you'd use a pair of 0.5-0.75uF caps or if you'd need to use half value if capping both inputs....or you could just cap the single output from the reciever if you're only using a single mono output I suppose.
Probably not really a problem worth worrying about in the first place, but it's an option if you're really nervous about damage and plan to crank it with really deep movie-sound-effect lows.
I think bass from music this low and this loud is so rare that it's not even a concern at 70watts or less.
