I like big drivers... Is there a song in that?
Bigger speakers/cabinets sound better than small ones with high excursion . . .
I'm guessing a 3way (or 4way) or 2.1 design could also minimize doppler distortion by limiting the worst of it to below 100-200hz while the midwoofers/tweeters barely move.
How well does something like that help for other distortions?....keeping the low-mids and high-bass barely moving and then letting a small, high-excursion subwoofer handle 100-200hz and below with all the distortion that brings.
Should that keep most of the distortion concentrated in the lower frequencies, or will the small subwoofer often create enough higher-frequency distortion to render this pointless?
If it does usually keep the dist limited toward the lowest frequencies, does that make it significantly less noticeable and bothersome to our ears/brains, or is LowFrequency distortion still going to be similarly noticeable?
I haven't seen much/any criticism about the Ultimax and RSS woofers creating noticeable distortion, so I'm guessing it's mostly a bothersome problem when the same small woofer is asked to handle midwoofer duty and deep bass at the same time?
Doppler isn't limited by going three way, nor does it keep the worst of it within the woofer or subwoofer pass band. Just as is the case with THD the driver creates above pass band harmonics not present in the signal sent to it. You don't hear Doppler or THD of a 100Hz tone at 100Hz. You hear it at 200,300.400,500Hz etc.
