Maybe consider the gold Fosi class A/V amp from the rainforest. Seems close to what you're looking for. I have not heard it though.
High Quality Mini HiFi Amplifier
Originally posted by tomzarbo View PostAre there any good, low wattage class A/B amps of small size that are noteworthy? For the intended use, small wattage needs, workplace use, so lower volume etc., I would think that one of those would be a nice sounding option. Kind of like the tube amp option, but easier to live with.
I can't think of even one though to be honest, maybe a DIY option with an amp board from other sites, but I don't think that was what the OP wanted to do.
I've heard this one only at a few PE events, but liked what I heard: https://www.parts-express.com/dayton...ifier--300-593
May not be small enough though depending.
I have, and still use the original Dayton T-amp, the one they redid from Sonic Impact or something like that... it has a curved top and can run off internal batteries... the PE one is black, that sounds good to me, kind of mellow and a little warm like an old A/B would. Source matters a lot though. Yeah, I'm no help.
TomZ
I built a Gainclone a few years ago, and loved it's sound quality. Sadly, I cooked one channel during crossover tuning.
It would only cost about $20 to fix it, just have to get around to it....
https://en.wikipedia.org/wiki/Gainclone
Tangband W6-sub
Interesting... I didn't know the history of the gainclone amp at all.
TomZZarbo Audio Projects Youtube Channel: https://www.youtube.com/channel/UCEZ...aFQSTl6NdOwgxQ * 320-641 Amp Review Youtube: https://youtu.be/ugjfcI5p6m0 *Veneering curves, seams, using heat-lock iron on method *Trimming veneer & tips *Curved Sides glue-up video
Having built and gifted the third system based on a pair of Pico Neo and small inexpensive chip amp, I'll give a recommendation on the fx502a (tpa3250) as a good mate. It's not the cleanest sound, darkest darks, smoothest or highest highs, and certainly not the best resolution; you get the picture, but it's sins are more that of omission that additive. I'm an 80's kid from back when perfect sound forever began. Part of that perfect sound was the shrieking highs of the new cd and the transition to transistors with their technically superior, lower distortion, sound reproduction capabilities.
Wish we would have had affordable good sounding options like these chip amps back then. It might have saved my bleeding teenager ears from being pierced by all that pins-n-needles technically perfect sound.
With that said, I've been eyeing the Icepower offerings on the bay and for an Andrew more than your $200 budget, a complete 125x2 Icepower amp can be purchased. Yes, it may be more than you currently want but there's a good chance it sounds much better than the inexpensive chip amps you might wind up with and this amp will not be a limiting factor when upgrading. And this is a DIY site so you know what the upgrade bug feels like.
- 1 like
Originally posted by djg View PostI was worried I was recommending a bogus amp, the Nobsound 2.1. So I dragged some stuff out to the living room to compare. The Nobsound, an SMSL SA50 2.0, a Sonance 75 watt per buyout amp, and a bunch of speakers. I did not have another 2.1 to compare, but I did run all three full range on the Zingers.
I really didn't hear anything bad out of any of the amps. Some of the smaller speakers suffer in a large room while sounding fine in a nearfield 2.1 setting.
I still recommend the Nobsound, I found it convenient to change sub parameters when switching between various speaker sizes.
Do you hear any hiss from the SA50?
The Nobsound was quiet. The SA50 I know from previous use is quiet. I didn't check it last night. I wasn't trying to discredit you, I was worried I was hawking a poor quality unit, and I actually never did any comparison like last night. I'm plug and play. I try to discriminate between things I heard in the forum, and things I hear myself.
Note the SMSL 24V brick I was using.
I need to sell some of these speakers.
Djg, I certainly didn't take your response as an attempt to discredit ... far from it. Nor was my response to discredit you ... it was just another experience I happened to have had with the same product and wished to share it with the OP for the body of experiences with these sorts of products. I just went through some reviews and only a few other people had experiences like mine and so I may still exchange it for another to try again and would upgrade to the 24V power supply from the 19V package for that amp. I did see that one other person had the sparking issue when plugging the amp in with both the supplied power supply and one of my own ... definitely the amp. Glad to know they were both quiet too.
Sparking is inherent in the design. The way I deal with it is to always turn off the amp, and it helps to use a power strip and turn that off before pulling the plug out of the amp. I was switching the power numerous times during my comparison, and got sparks a couple of times when I forgot the regimen.
The Dayton amp has the same feature set basically, but the wonky mix of controls and labelling has me favoring the Nobsound's almost vintage row of silver knobs.
TomZ
Are you this the one you intended to link, Tom? When I click the link I see class D right in the title description.
I was wondering the same thing about small AB's. Not the same small size factor but I have a half width and shorter than full size Emotiva a-100 that sounds great and I wonder about the Parasound Zamps. Still would like a smaller AB.
Kornbread brought up the icepower modules and I happen to be building an amp with one right now. This is a 50asx2 along with a CMoy based preamp and Alps pot all crammed in a 4.5" x 2" x 8" aluminum chassis. If you built it as power amp it would be much more simple.
Originally posted by silverD View PostKornbread brought up the icepower modules and I happen to be building an amp with one right now. This is a 50asx2 along with a CMoy based preamp and Alps pot all crammed in a 4.5" x 2" x 8" aluminum chassis. If you built it as power amp it would be much more simple.
Originally posted by Kornbread View PostIs the Alps at the input? What model Alps? Build log?
Nate
TomZ
But they are around used I'm sure.
When class D amps with higher wattages started getting popular, I think folks became intrigued with the low cost for the watts available, and the high efficiency, and some steered away from traditional AB amp tech.
Maybe we'll see a few more old school type amps hit the marketplace as folks seek higher quality audio in the future.
I ended up purchasing one of these - SMSL SA100 Bluetooth 5.0, 50W/Ch@4 Ohms for ~$75. It's a TPA3116D2 based amplifier, and the form factor is a little different than most which adds a little visual interest. It'll be mainly used for some background music while working in the office along with some small Tang Band W3-1364SA based towers. The Amazon description says something about a replaceable tube, but it must be a copy and paste error from some other amplifier.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
TomZ
New units like Cambridge are very good. but now big and expensive. There is a lot of data on how to build a chip-amp as well as the technology allows. I built a couple A/B based on cheap kit boards I got from China, but modified as best of my knowledge from reading the likes of Cordell, Self, Pass, Leach, etc. as a learning experience to see how good I could get. Best was not far from a 'Blameless" but with 4 pairs of outputs instead of one. Too bad I tested it to destruction. Are you going to buy a $100 true hi-fi class AB or A amp? No. I learned enough to build a MOSFET based amp that I may put back in service as the new "upgraded" Parasound 2124 seems a little compressed even though it is twice the power.
