Hey there Tech Talk,
I'm looking to make some small, wall mounted surround speakers for my home theater... I will eventually create a proper thread in the Projects Gallery, but for now want to get your thoughts on the basic concept here.... This design will be based on the Chito HT design, using the using the RS100-4 woofer and ND16 tweeter.... big thanks to Navy Guy for the hard work on the Chito. See the link here for more info....
http://techtalk.parts-express.com/fo...0-4-and-nd16fa
My idea is to 3D-print a double-walled vented enclosure that I will then fill with concrete. No mold to remove or anything, just fill it, let it cure, and it's done.
Overall dims are 10.5" tall x 8.25" wide x 4.25" deep. The volume is 1.7 liters with a 1.125" x 6.5" port, as per Navy Guy's specs. It's not quite a cylindrical port as you can see; although the cross-sectional area of the port is exactly the same as a 1.125"....
The overall thickness of the wall is 5/8", with 3/8" of concrete at it's core, and .5" of concrete on top.... I think it should be feasible, based on small DIY concrete flower pot projects that I've seen....
The first few pictures show the 3D-printed enclosure before the concrete pour. Note how the port is formed right into the enclosure, so no need to add a port.
Here you can see after the concrete is poured.... note how the concrete is poured from the top, shown in light gray here...
Here you can see the bottom of the enclosure, with the 3D-printed cover in place (yellow, no screw holes yet)... the crossover will be on the top of this cover. for easy access.
Other thoughts:
Thanks
Dan
Other thoughts:
- The inside walls with be lined with 1/2" foam.
- It will be crossed with a big 12" sub at 80 hz, so low-end performance is not super critical... that being said, it should play fairly well full-range, as it is the correct
- 4 beefy eyelets (not shown) will be designed into the back for secure wall palcement.
- Terminals will also be on the bottom cover.
- The port does have a slight flair at either end, although I don't imagine this will be terribly meaningful for such a small speaker.
Thanks
Dan
