I just wanted some people opinions and experiences with solid core inductors vs air in low pass filters in the average 3 way design say below 400 hz. While we are on the topic do bipolar electrolytic caps perform acceptably compared to poly caps that can get costly and huge(low pass only)Need the info for an upcoming build and would like to cut costs but not if too punitive to sound quality. Would appreciate the input.
Do air core inductors make a noticeable difference over solid inductors low pass
Originally posted by billfitzmaurice View PostIf anything cored may be better, as they will generally have lower DCR. DCR is the criteria by which I choose both type and wire gauge. NPE are OK for low pass, as all they do is shunt to ground, so their higher ESR is of no real consequence.
Not disputing use of an NPE in the low pass is not a reasonable cost substitution. Not disagreeing with iron core inductors for LP. But please go learn just a little bit about electronic theory before leading others who also do not have an electronics background astray about location of the component in the network. All current is in the signal path. This is AC.
Originally posted by Regore View PostIron core inductors are non linear at higher current levels and will saturate. Air core inductors have no core so can't saturate.
Lower DC resistance comes at a price, no free ride.
Probably dumb question, but does that mean feeding too many amps is the potential problem (aka, generally staying under a particular wattage should keep things safe)?
If so, I'm assuming the spec'ed wattage rating is just a heat-dissipation of the resistanceVSwire-gauge, not anything directly related to core saturation?
https://hificompass.com/en/projects/...core-inductors
Good article here where the increasing distortion is a measure of the non-linearity
- 1 like
Is reading a chapter in the Loudspeaker Design Cookbook considered "doing research"?Craig
