Some of the Dayton RS100's have an off-axis peak around 2khz. It might be worth checking if that older RS100ps is the same. If it IS, then it might help to cross to the tweeter a little lower below that point (unless there's another way to fix it maybe?).
Off axis "flares". Why do they happen? How to fix them?
If I remember correctly, Grimm Audio had a white paper on their website about the development of the LS1. It was a pretty good read on their development and thought process concerning the large roundovers and how they turned the DSP for off axis performance
Originally posted by LOUT View PostSome of the Dayton RS100's have an off-axis peak around 2khz. It might be worth checking if that older RS100ps is the same. If it IS, then it might help to cross to the tweeter a little lower below that point (unless there's another way to fix it maybe?).
One of the reasons why I also thought about the RS driver being the culprit is that the tweeter doesn't exhibit any off-axis flares, and I'd expect them too. And simulations never showed this issue.
Do you know where I can find info on the off axis performance of the RS-100?
2-2.5 Way:Zaph Audio's winning entry: ZA5+SB29. - Microliths: RS125+RS28. - Small Bangs: TB W4-1658SB+SEAS 27TBFC/G. - Monoliths: Peerless 830884+SEAS 27TBFC/G.
3-3.5 Way:Miniliths: SEAS P21/CA21REX+Neo8 PDR+Neo3 PDR. - Megaliths: 2xDayton RS270+2xT-B W4-1337SB+SB29. - ZDT3.5 +: 2xDayton RS180+Dayton RS52+Vifa DQ25. Reflexos: OB 4xDayton RS150 + Neo3 PDR.
Line Array: IDS-25 Clone, FE-83.
Well that is interesting! I have a pair of RS100-8 sitting and waiting to do mid in a 3 way project, I wonder what they'll do.Electronics engineer, woofer enthusiast, and musician.
Wogg Music
Am I correct in my memory that Jeff said something about how you can use a trap and smooth out an on axis spike, but the off axis power response will still be funky?
(I'm probably wrong....)
I once had a 3 way were I was trying to use a Vifa TC9 mid slightly recessed. It sounded great on many music cuts, but real funky on some.
Not trashing the Vifa, it might have been my misguided attempt to rear mount it.
The only thing I found was a little bit of a hot power response right in the middle of it's passband.
I finally gave up, and flush mounted a different mid, and it immediately sounded better.
Tangband W6-sub
Originally posted by fjhuerta View PostThis off axis peak is so big I actually thought it was the driver. I have seen diffraction, but this is far too much... and far too prominent. Unfortunately, the peak starts at 1.5 KHz, so crossing over that low, even a Dayton RS28F, is cause for concern (and the reason why I started using 8th order filters).
Of course, if there's a better way to solve this, then totally go for that instead..I'm just saying that crossing to the RS28 around 1500hz might be a viable backup plan if there isn't a better solution.
Originally posted by rpb View PostDid you filter (EQ) the mid to follow a 4th order target on axis, or did you just dial in a 4th order filter?
I did some measurements today and have a definite idea of what's going on. It's diffraction from the edge of the baffle.
I took some scotch-brite pads (got the idea from a DIYaudio post) and taped it to the edge of the speaker, next to the mids and tweeter. The hump at 2 KHz did not disappear, but it dropped 1 dB, and I flattened the response on the tweeter a lot.
Obviously, I will not leave the scotch-brite taped. I wanted to get some 1/2" x 2" F10 felt from McMaster-Carr. But they won't send the material to Mexico. So, at least for now, this plan is a no go.
What I did was - I started taking off and on-axis measurements, and discovered that a 2 dB BBC dip on axis flattened the response off axis, and created smooth, downward slopes, Adjusting the woofer and tweeter levels a bit, I got a smoother response than I expected.
I then took several measurements on my sitting position and noticed the FR was downward sloping, without any major dips or bumps. So, I assumed that I had properly considered both on and off axis curves.
I listened to music, and the midrange glare was gone, replaced by a very smooth midrange and upper mids. The speakers are now really enjoyable.
I may try and get some F10 felt, but honestly, at this point, I'm really happy with my speakers. Form followed function in this box. But my next one will be 100% function.
Nevertheless, I'm really happy, and I learned a ton with these speakers. I posted this after two months of tuning them. I finally arrived at a combination that I know I'll be happy with (and I'll never design a passive speaker without testing it with the MiniDSP first!).Line Array: IDS-25 Clone, FE-83.
Hey, glad to see you back in the DIY world Francisco. I still remember your winning design in Zaph's contest all those years ago. I used a slightly modified version of your SB29 tweeter xover with a different woofer and it turned out great. Thanks for that!"Everything is nothing without a high sound quality." (Sure Electronics)
Originally posted by ernperkins View PostHey, glad to see you back in the DIY world Francisco. I still remember your winning design in Zaph's contest all those years ago. I used a slightly modified version of your SB29 tweeter xover with a different woofer and it turned out great. Thanks for that!
I just decided to get serious about this issue, and post my findings. I bought 1/2" x 2" F13 wool from McMaster (I had to use a forwarder to send it to Mexico) and 1/2" x 2" Neoprene. I'll try to find out which one works best for my issue. I hope it's the neoprene, since I think it'll look better than wool felt my baffle. I'll post all of my findings in thes thread!Line Array: IDS-25 Clone, FE-83.
Thanks! Yes, I loved that design. I still have 4 boxed ZA14's from that timeframe, which I may use this year.
dlr
Originally posted by dlr View PostI doubt seriously that the neoprene will be a benefit. The sound waves needs to pass through the material and absorb some of it. It may also be that it adds some delay as well that changes the phase after it has passed through, but that part is just my conjecture. My thinking on that is that the speed of sound through something such as felt is different than in open air. I have found very few materials appreciably improving diffraction effects.
dlr
The idea for neoprene came from here:
https://www.courant.com/news/connect...039-story.html
https://web.archive.org/web/20120124...ig-tweaks.html
From what I understand, wool felt helps with sound dispersion, while neoprene actually does sound absorption.
I do believe wool felt is the answer to my problems. But I hope neoprene does the trick, since I'm sure it will look better than the felt. Anyway, measurements will show which one does work.Line Array: IDS-25 Clone, FE-83.
From what I've read and seen with data, felt does a definite improvement in the area I need to, and a very small amount of synthetic fiber already got me halfway there. I only need to shave an extra dB off 1.5-2.5 Khz.
dlr
