Has anyone else worked with the T-B W3-2141?
Collaborating on a project and pulling some early data, and they seem to measure drastically different from published.
This is taped to the baffle not flush-mounted, so I'd expect a little diffraction but not the 10dB peak at ~2900Hz and the dip at 4k. Impedance changes shape like spec, but at ~3200 vs ~1600
Update: T/S parameters for the two drivers I've been measuring.
Loudspeaker parameters:
Fs = 124.79 Hz
Re = 7.10 ohm[dc]
Le = 55.99 uH
L2 = 340.99 uH
R2 = 4.47 ohm
Qt = 0.47
Qes = 0.65
Qms = 1.75
Mms = 1.82 grams
Rms = 0.814988 kg/s
Cms = 0.895738 mm/N
Vas = 1.15 liters
Sd= 30.19 cm^2
Bl = 3.956203 Tm
ETA = 0.33 %
Lp(2.83V/1m) = 87.83 dB
Added Mass - Constant Bl Method:
Driver unbaffled
Added mass = 3.20 grams
Membrane Diameter= 6.20 cm
Fs = 126.60 Hz
Re = 7.10 ohm[dc]
Le = 55.29 uH
L2 = 317.53 uH
R2 = 4.68 ohm
Qt = 0.43
Qes = 0.60
Qms = 1.52
Mms = 2.31 grams
Rms = 1.213469 kg/s
Cms = 0.683138 mm/N
Vas = 0.87 liters
Sd= 30.19 cm^2
Bl = 4.662416 Tm
ETA = 0.28 %
Lp(2.83V/1m) = 87.15 dB
Driver unbaffled
Really disappointing results.
C
Fs = 124.79 Hz
Re = 7.10 ohm[dc]
Le = 55.99 uH
L2 = 340.99 uH
R2 = 4.47 ohm
Qt = 0.47
Qes = 0.65
Qms = 1.75
Mms = 1.82 grams
Rms = 0.814988 kg/s
Cms = 0.895738 mm/N
Vas = 1.15 liters
Sd= 30.19 cm^2
Bl = 3.956203 Tm
ETA = 0.33 %
Driver unbaffled
Fs = 126.60 Hz
Re = 7.10 ohm[dc]
Le = 55.29 uH
L2 = 317.53 uH
R2 = 4.68 ohm
Qt = 0.43
Qes = 0.60
Qms = 1.52
Mms = 2.31 grams
Rms = 1.213469 kg/s
Cms = 0.683138 mm/N
Vas = 0.87 liters
Sd= 30.19 cm^2
Bl = 4.662416 Tm
ETA = 0.28 %
Driver unbaffled
C
