Originally posted by Chris Roemer
View Post
Unsatisified with the Sound of My Newly Built Amigas - Options?
Wasn't polarity mentioned in post #2? Which was met withI have both speakers connected in phase. I'm new at building speakers and xover's, but I know enough about wiring to ground and knowing the difference between + and -
Originally posted by Kornbread View PostWasn't polarity mentioned in post #2? Which was met with
I made a couple tweaks. I replaced the 2.4 ohm resistors of the tweeter L-Pads with 5.1's that I had on hand, and I removed about 30% of the stuffing from the upper third of the cabinet,
and magic occurred. The coloration and darkness have disappeared, and I am now smiling when I listen to the Amigas.
It's hard to believe such small changes made such a huge difference.
Originally posted by audiojerry View Post...and I removed about 30% of the stuffing from the upper third of the cabinet, and magic occurred. The coloration and darkness have disappeared, and I am now smiling when I listen to the Amigas.
"The interior walls of the enclosure need to be lined with some sort of convoluted foam or BlackHole (honestly, I use mattress topper from Wal Mart). There is also a wad of stuffing resting in the bottom 1/4 portion of the cabinet."
Originally posted by a4eaudio View Post
Per Paul's write-up there would not be stuffing in the upper 75% of the cabinet, but rather lined with some sort of open cell foam.
Any members living near Brookfield Wisconsin is welcome to listen to the results (when Covid immune)
I appreciate everyone's advice and suggetions and enjoy the snarks too.
Originally posted by billfitzmaurice View PostYou will see the effects of both lining and stuffing in SPL charts, waterfall charts and impedance sweeps. Some modeling software will show it, but only if you know the airflow resistivity of the material used.
For anyone inerested, after reporting great sound after replacing the 2.4 ohm resistor with a 5.1 ohm in the tweeter l-pad, I noticed the sound getting brighter and brighter after seveal hours of continued listening. Could this have been continued break-in burn-in of the xover? I don't know, but I went back and replaced the 5.1 with the 2.4, and let the speakers play burn-in sounds for another 100 hours. And now the Amigas sound wonderful. I am extremely pleased, although like others have reported, they have a limit to how loud they can go. When I want to go really loud I use my modified 1979 vintage Klipsch LaScalas.
For 80% of what I listen to the Amigas equal or surpass any floorstanders I have used including some $6k models. Now I have to wait for warmer weather for finishing and painting outdoors.
I did not notice that so much with my Amigas, but I just recently finished a pair of Classix 2.5, and had the same problem. I was very unhappy with their sound at first. I thought I wired them wrong. I let them burn in, and I love them. Totally different speaker. Sent from my SM-G973U using Tapatalk
Crossovers don't burn in. They can't, they don't have moving parts. Drivers do burn in, especially woofers, but not by that much. If you had a new driver next to one with forty or more hours on it you'd probably notice the difference, but your hearing memory is far too short to notice the difference over time. You do get used to the sound of a new speaker over time, so to some extent you could say that your hearing burns in to the speaker.
Originally posted by billfitzmaurice View PostCrossovers don't burn in. They can't, they don't have moving parts. Drivers do burn in, especially woofers, but not by that much. If you had a new driver next to one with forty or more hours on it you'd probably notice the difference, but your hearing memory is far too short to notice the difference over time. You do get used to the sound of a new speaker over time, so to some extent you could say that your hearing burns in to the speaker.
Originally posted by johnny5jz View PostThat's not totally true. Capacitors are known to burn in. Again not a huge difference, but they do. There was just a slight harshness in the midrange with my speakers. I did an A B comparison with other speakers, then let them burn in. Afterwards it was gone. Sent from my SM-G973U using TapatalkFrancis
