I'd like to put some resistors in series with the front tweeters in my car stereo system to pad down the highs somewhat. The resistor(s) will be connected between the hot lead from the radio and the crossover cap. Assuming a 4Ω tweeter, a 2khz crossover frequency and a head unit with 15watts/channel, what should my resistor's power ratings be? I'm estimating I'll need 50Ω or less.
Resistor power requirements in car system
You should use an L-pad configuration with 2 resistors and they should go between the crossover and driver, see the link to determine what resistor values you need.. L pad calculator - attenuation dB damping impedance decibel loudspeaker speaker voltage divider - sengpielaudio Sengpiel Berlin
5w resistors will be sufficient if you do it this way.Paul O
- 1 like
Originally posted by swechsler View PostIf I don't care about maintaining a specific impedance, what's the advantage of an L-pad over just a simple series resistor?Electronics engineer, woofer enthusiast, and musician.
Wogg Music
