guys, i bought this Visaton W130 X - 2x 4 ohm driver last year in order to use it as a sub on a 2.1ch build, which i'm still planning to do with my latest chats about minimal desk setups and small pc speakers.
https://www.visaton.de/en/products/d...30-x-2-x-4-ohm
it mentions that you can hook up one voice coil, or both either in series/parallel, which has thrown me a little. I've seen some basic bluetooth builds where there has been 2 woofers and a shared tweeter, but pretty confident in my thinking that you cannot just hook each voice coil to a different channel and share a sub in the same fashion? ie do a fast crossover and combine for the sub. Am i correct in thinking this?
I'm still thinking about my amp selection as it needs to be small and minimal, but i have a no name 2.1ch amp (2x50 and 1x100w) and a wondom 2x50w bluetooth board with DSP, which the later i bought for my phantom clone, but then realised it didnt have the charging chip and i ended up going the mono 60w amp instead. I also was thinking this could make a bit of noise in a bluetooth setup, as originally i got the peerless 2.5inch full rangers (830985 https://www.parts-express.com/Peerle...oofer-264-1050) which can be in a small sealed box 0.01cuft with a F3 of about 140hz. Only issue is i only have two ears and with an autistic child i dont always get to crank up the volume and i seem to have quite a few small BT builds to date,
I like this woofer as it can get an F3 in the mid 40's and be in a enclosure of 0.140-0.15cuft, which is quite compact for a 5 inch, well i think it is.
being mounted under a desk facing downwards, i dont know if a BSC is required as it will probably have a low pass filter around the 150/200hz range, but interested to hear some thoughts on it.
