RS22528A
  • RS22528A
    Provided Link: http://206.13.113.199/ncdiyaudio/mark/index.htm
    Part 1 is here.
    audioheuristics isn't around right now...
    Hey Mark, A quick question
    How critical is your driver spacing? I can imagine the answer might be that it's very critical but I'm wondering if they can be placed closer to one another. I'm contemplating a few options for my RS225 project, one being a two way TL design. With the gracious guidance of Paul K I think this might be the way I will go but it all hinges on the performance of the new RS midrange if I go 2 way or 3 way. If that unit is as good as the rest of the RS lineup, I'm all set. If not, 2-way here I come but I would want the drivers to be a bit closer if for nothing else than aesthetic reasons. Thanks.
    shawn
    My favorite woofer is a Labrador retriever.
      Re: Hey Mark, A quick question
      Well, no reason the drivers can't be closer. But because of the low crossover, there is some leeway on the CTC spacing. Plus, the axis tilt from the tweeter horizontal offset is a bit less. All in all, I don't think it would matter.
      Of course any changes to the layout/baffle would require a different set of xover values.
        Shawn, I'll let Mark answer you regarding his crossover design, but keep in mind that Mark used a PE cabinet whose width, I believe, is less than the cabinet design I worked up. You'll have to make my cabinet design narrower and deeper to accommodate Mark's crossover and, at the same time, keep the cabinet volume as I designed.
        Paul K.
        > shawn
          Re: Hey Mark, A quick question *PIC*
          > shawn
          Shawn,
          I've got a ML-TQWT design using those very drivers that Roman Bednarek and I worked out . . . if you're interested.
            > Shawn,
            Also have one with the SEAS 27TBFC instead of the RS28
              Thanks for all the info gents!
              First off to Mark. I understand completely the baffle width considerations. I was going to use your crossover as my starting point and tweak for the different baffle width. I like what I see in your plots enough to think it's a great place to start.
              Paul, I figured you would jump in on this thread too ;). I appreciate all of your input and development of the TL design. I'm going to do it for sure but it probably won't be until spring when I finally start cutting the wood. That is unless everything else I have on the to-do list suddenly evaporates. Winter time is usually my time to work on my house and it's really in dire need of the attention this time around. I will be picking up some of the RS mids very soon. I'm anxious to see how well they perform.
              And Pete, thanks a ton for the offer. I like the lines of what you and Roman have come up with. I am always interested in different projects that I've not tried before and I've been wanting to try my hand at a TQWT. I was leaning towards trying a pair like what is on the project showcase but this is a great option for sure. Any further info you care to share would be greatly appreciated.
              Once again, thanks guys. This is the very reason I love this forum. Great advice and great people. Have a good one.
              shawn
                That's a great-looking design, Pete, but my space is too limited to handle such a tall cabinet, and even if it wasn't, I know my wife would say NO!
                Paul K.
                  > wife would say NO!
                  > Paul K.
                  The cabinet can be folded over to make a design only 3' tall in a more conventional style. The main point was just to display the TL shape, length, and port tuning.
                    Re: Thanks for all the info gents!
                    > perform.
                    > shawn
                    The XO is of similar topology, very steep slopes around the 1.5KHz mark. The cabs can be "folded" above the tweeter to create a more conventional style design instead of the large triangular presentation.
                    But now that the RS mid is out, I may want to revamp the design to incorporate them in the 600Hz range. As nice as the RS225 is, I'm just not sure of using it that high up.
                    I'm anxious to get Mark's listening impressions. The system sure looks like it measures well. I can't help thinking it will sound very nice to moderate listening levels, but I just worry about them at crescendo.
                    Let me know if you need more detail.
                      Lots o measurments!
                      Great work dude. I've played with the 225 using Darren's measurements and seems like it could go up to around 1500 Hz with a C-e crossover. But no real need if the RS28 holds together lower.
                      Too bad the PE box isn't a bit wider...wonder what a RS270 two-way would be like at 1200Hz except there's that mode at around 1KHz. Maybe crossed lower with something like a Neo8...
                      Dave
                        Curt's Speaker Design Works
                        "It is the mark of an educated mind to be able to entertain a thought without accepting it."
                        - Aristotle
                            Re: Nicely done, Mark!
                            can someone help me get the x- over design to this build?
                              Originally posted by curt_c View Post
                              60 liters tuned to 24 Hz would provide an f3 of roughly 30 Hz, and nearly the same power handling above 20 Hz as compared to a sealed design with a Qtc of .7.
                              So this is possible with the same crossover?
