Vifa Dome Midrange Opinions
  • Vifa Dome Midrange Opinions
    I'm trying to decide on dome midranges and was wondering if any of you have had experience with Vifa D75MX-41-08 3" Textile Dome. I am also considering the Morel MDT-55, and know from previous comments that it is an excellent driver - I remember Wolf and others thinking it was one the best sounding midranges they have used. Unfortunately and based on my initial modelling, it simply does not have enough sensitivity for what I need. The Vifa 3" should.
    Is the Vifa 3" really as good as the PE reviews? As much as I like the reviews portion of the Parts-Express website, I take them with a grain of salt.
    How does the Vifa compare to the Morel MDT-55?
    These are going in 3 way wall mounted LCR HT speakers in a custom setup behind and to the sides of the screen.
    Initial plans are 2 Dayton RS225's, 1 Vifa 3" Dome, and Vifa Vifa XT25BG60-04 Double Magnet Ring Dome Tweeter in a WTMW array and vented enclosure. Since these are going on the wall behind the screen, I do have some leeway with box size, shape, etc.
    - Scott
    Re: Vifa Dome Midrange Opinions
    For my design, I was initially planning on using the Vifa driver, because of its sensitivity and really good reviews, however I was persuaded to move away from that driver just because its an old design, and its a little bit expensive for what it does. I have heard very good reviews about the Morel 55 as well as the Dayton dome mid range drivers though, and it seems as if most people suggest these drivers over the Vifa. Quotes that were replied to me:
    "For the mid, I think the dayton rs52 would be superior to the Vifa D75 (which is very old)."
    "Don't go with the Vifa dome. From personal experience, the Morel MDM-55 is much better. From what I've heard, the Dayton dome is also better."
    Hope this helps!
      Re: Vifa Dome Midrange - Other Options
      Hi-Vi also has a pair of Dome midranges that I should consider as well. Does anybody know much or have experience with them?
      - Scott
        - Scott
        John Kreskovsky designed a kit with the non-neo dome mid for E-Speakers. This is a much larger faceplate HiVi 2" dome-driver available from Mad/E-. Other than that, I don't know of much research on those.
          - Scott
          I did a 3 way [ the Bellaria ] with the HiVi DMNA. I found it quite capable, and easy to work with.
          Lou's Speaker Site [speakers.lonesaguaro.com]
          "Different" is objective, "better" is subjective. Taste is not a provable fact.
          Where are you John Galt? I may not be worthy, but I'm ready.
            Thanks Lou,
            I haven't seen a HiVi used yet. i checked out you website and found it quite helpful. Thank you all for the advice.
            ~ Scott
              I used the Vifa 3" dome in a speaker system I built in 1986. That's 22 years ago, and IIRC I wanted a 3" dome, because of the greater piston area. It was an excellent speaker system; I only wish i kept the design details.
              Bear in mind that was indeed 22 years ago, so it's no stretch to say it's an old design. Of course, I am an old design as well, and do not wish to be put out to pasture !
              If I were to use a 3" dome again (which is highly unlikey) I would use the ATC.
              The really odd thing about that Vifa was, it's backplate was green cloth, sorta like pool table felt, glued over & covering multiple escape holes drilled in the back. I used a back chamber.
                Scott L
                I assume you are speaking of the ATC SM75-150 3" dome midrange. Where do you find these?
                Also, why wouldn't you use a 3" Dome midrange again? Personal preference, the fact that there are only couple on the market, or is there a technical reason that I do not know about.
                Thanks again for everyone's input.
                ~ Scott M
                  Hi Scott M,
                  The availability of the ATC dome has seriously diminished over the years, plus they are quite expensive. I don't know how much the Vifa 3" costs these days, but, I'd bet you could get one of the offerings at PE for a 2" dome at comparable dollars. I also remembered since posting this morning, I had also used a 2" aluminum dome in one of my speakers systems. I can't remember the brand, since I have built soooo many speakers over the years, but, I do remember it had a rubber surround, odd eh ?
                  I have nothing against a dome mid, it certainly fits certain applications, but, for me personally, I don't cross-over at where a typical dome would (say
                  700/800 Hz). These days, I build much, much larger systems, and use a single 7" cone to cover from 250- 5,000 Hz.
                  A fabric dome would also be easier on a crossover, I think I had to notch out a peak in that aluminum job...... again, it was years ago.
                  I think some of the other contributors to this thread mentioned the PE 2"
                  --- most likely a good value/ performance ratio for your application.
                    Available Mid-Domes Past/Present/Future(?)....
                    Scott L
                    ~ Scott M
                    6" Dome-woofer:
                    I don't know who made it, but a fellow poster ("Herb") found a set. These were probably meant for waveguides in a prosound setup, and weigh-in at 13 pounds.
                    3" mid-domes:
                    Dyn D76 and AF.
                    ATC SM-75 (available now from Solen.ca, and $$$$$)
                    TB 75-1558SE
                    Morel MSD-76 (USA/Renaissance-made, and I think the model number is right.)
                    Accuton C90-6-79
                    Vifa D75MX-41-08
                    Volt VM752 (Solen-$$$$old, and looks a LOT like the ATC!http://www.solen.ca/photos/volt/vm752.jpg)
                    2":
                    Usher 9845
                    Phillips AD0210/variants
                    Morel MDM55, EM1308
                    Dayton RS52AN-8, DC50F-8
                    HiVi DMN-A, DMB-A
                    LPG 51AT, 50FA
                    TB 50-1426SA
                    Accuton C50-8-44
                    Visaton DSM-50FFL
                    Peerless (India) ??
                    1.5":
                    SS D3806/8200
                    Audax TW034X0
                    I'm sure there are more available in the lists from past/present, but I cannot recall/find anymore. If anyone knows of more, please add to the list!
                    Last edited by Wolf; 09-13-2008, 07:51 PM. Reason: Found LPG textile model number, added the 6" dome-woofer.
                      Re: Available Mid-Domes Past/Present/Future(?)....
                      Originally posted by Wolf View Post
                      6" Dome-woofer:
                      3" mid-domes:
                      Dyn D76 and AF.
                      TB 75-1558SE
                      Accuton C90-6-79
                      Vifa D75MX-41-08
                      2":
                      Usher 9845
                      Morel MDM55, EM1308
                      HiVi DMN-A, DMB-A
                      LPG 51AT, 50FA
                      TB 50-1426SA
                      Accuton C50-8-44
                      Visaton DSM-50FFL
                      Peerless (India) ??
                      1.5":
                      SS D3806/8200
                      Audax TW034X0
                      Wow Wolf, thanks a lot man. Its been a while since I've been active on the boards - I think I last posted before the switchover to this new discussion interface. I remember reading a thread that you had hit a some number in posts. How many do you have now?
                      In any case, your last post is way more information than I would have ever anticipated and I am going to enjoy looking these up. I'm really curious about the Tang Bands. Of course, I really don't care if the mid is a 2" or 3", I just want something that will bridge that performance gap between the RS 270's and the tweeter, avoid that aluminum cone breakup and help with the overall power handling. I've sizzled some tweeters before crossing them to low.
                      I'll keep you all posted as things move along. If I get this CAD software to print some pdf images, I'll post some initial designs...
                      Thanks again for the advice - esp Wolf and Lou
                      ~ Scott M
                        Wolf? He's at 6.544kp... (6.544 kilo-posts, 6,544!)
                        Nick
                        I'm just that guy. www.sru.edu Rock Solid.
                        "It has been remarked that if one selects his own components, builds his own enclosure, and is convinced he has made a wise choice of design, then his own loudspeaker sounds better to him than does anyone else's loudspeaker. In this case, the frequency response of the loudspeaker seems to play only a minor part in forming a person's opinion."
                        L.L. Beranek, Acoustics (McGraw-Hill, New York, 1954), p.208.
                          Re:6" Dome-woofer/ Wolf
                          How do you guys get that gray box to appear, such that the post I am responding to, shows up?
                          Wolf:
                          When you cited the example of a 6" Dome-woofer:
                          I remember a Morel 6 inch (not 6 1/2) woofer, with a voice coil so big, and a dust cap even bigger, that it looked like a huge dome, BUT, it was no where near 13#. I wish I knew what "Herb" found. Waveguides, and pro-sound are in my vocabulary. Thanks !
                            I did quite a lot of research into domes awhile ago, for me they didnt suit my dual woofer design (I needed something to get down to 300hz).
                            The best I found was the Visaton DSM50FFL titanium dome, usable response 800-15k, the only other one I would consider is the Dayton RS52 which is newer.
                              Re: 6" Dome-woofer/ Wolf
                              Use the "Quote" button within the individual posts.
                              Brad
                              piano black sealing mdf irregular recesses grill technique
