Proper application of polyurethane - Need help
  • davepellegrene
    Re: Proper application of polyurethane - Need help
    Originally posted by jerryanderson View Post
    I assume this would be some kind of sponge or foam rubber roller?? Would one like a small decorative roller be used for small projects? I will pursue this further when the weather gets a little warmer around here!
    http://www.boatbuilding.net/article....6/04/04/120201
    Here is an article I was reading when I was researching for my jump surface. It has a lot of good tips in it. I like the part to heat stuff up. I had issues with varnish as I was spraying it on some cabinets I built. It was cold and I heated the shop up and sprayed with cold varnish and cold surface and the finish looked like it had goose bumps. I had just red this article and heated up the varnish and put the cabinet in front of the heater. Sanded it back down and resprayed it. It came out really nice!
    I have been heating my stuff up since and the finish seems to flow much better.
    I just built a sub Thursday and sprayed it with auto finish using the heating method. So far as its drying it looks good.
  • davepellegrene
    Originally posted by bobbarkto View Post
    Just in case...
    Be aware that most clear epoxy will degrade very rapidly when exposed to UV light. It will discolor in less than a few months and deteriorates quickly after that.
    Some marine products have stabilizers added to combat this, but pigmented epoxy (eg: paint) with stabilizers has the best UV resistance.
    Thats good to know especially with the jump surface. It is suppose to have a contrasting color to the water, like red, so pigmented is a good idea.
  • bobbarkto
    I use a very short nap synthetic roller cover.
    Useing a slow set hardener is a good thing.
    Heat accelerates the curing process exponentially.
  • bobbarkto
    Just in case...
    Originally posted by davepellegrene View Post
    I have been doing a lot of projects using epoxy. I now you can spray it with the right equipment. I just used an epoxy with a 90 minute set time. I used it to fill in between pieces of granite. It seemed to flow out really nice. Made me think you could probably roll it onto a project and it would have time to flow out smooth. You can also add color to it. I am getting ready to put a new surface on my water ski jump. I will be using sheets of cdx plywood coated on all sides and edges with an epoxy prime then probably two coats of epoxy. This will be a good place to see how it flows with a roller.
  • jerryanderson
  • davepellegrene
    It would be an interesting project. I may get a smaller quantity and do a little finishing on some scrap woods I have laying around and see how it works!
  • jerryanderson
    My local Home Depot has it.
  • davepellegrene
    It can be built up! Has many uses...I found out about it through my other hobby, model railroading. Modlers use it to model lakes and streams on their layouts and you can build it up. I know bars use it to protect the wood from water stains or patrons crying in their beer??? Other have used it for decopage! I have used it for small streams on my layout and it dries very clear! It smoothes out by its self...no streaks!!
    It does take some time to set up and dry, so on speaker cabinets its one side at a time! Patience is required with this stuff, but the payoff can be quite stunning! It can be purchased through your local hobby shop. Ask if they have it on hand or look through the Walther's Model Rairoad Catalog. Its in the scenery section of the HO scale catalog or go on line to www.walthers.com and order direct from them. They have an excellent online/mail order system!
    You might try your serach engine and see if you can find Enviornmental Technologies Inc. online! You could also try local hardware stores etc. and see if they have it!
  • jerryanderson
    Originally posted by brianpowers27 View Post
    I wonder if it has low off gassing... It sounds like it stinks but that may go away. Does it build nicely?
    BTW: Where did you purchase this product.
    It can be built up! Has many uses...I found out about it through my other hobby, model railroading. Modlers use it to model lakes and streams on their layouts and you can build it up. I know bars use it to protect the wood from water stains or patrons crying in their beer??? Other have used it for decopage! I have used it for small streams on my layout and it dries very clear! It smoothes out by its self...no streaks!! It can be brushed on, but be careful with a second coat! Allways keep the applied surface flat and even!
  • arlis_1957@yahoo.com
    get yourself a couple of small mason jars and mix your poly with thinner 50/50 and use it as your first coat, seals and dries very fast. put a couple of undiluted allowing to dry completely and use the gray scotch brite pad, i get mine at home depot, use it with a block of wood. make sure you have very good light for this. tack well, then wipe on the last coat with the mix. or spray on. if you just cant get it to dry without nubs and bumps. then buff once more with the grey or if you can find it the white pad. the get som paste wax, cut a couple of inches off one of your white socks, put a little of the wax in it and rub the sock on your surface the wax will seep through and leave just enough on your surface. let dry buff well. i use a pad on my ramdom orbit sander.
  • davepellegrene
    I have never felt good about my hand sanding technique, especially around corners. I ended up using 000 steel wool to smooth things out and applied a thin brush coat this morning. I imagine that I will use 0000 and try one final coat. I really like a thick build. I imagine it is likely to be a little more durable, with the build.
    Instead of steel wool I like to use a red scotch brite pad. You don't get the little pieces of metal. Like Bif said even lightly sanding will take out the bumps and give you a smoother finish. The steel wool or scotch bright pad wont do that. If you want a hand rubbed finish after your last coat you can buff it with the 0000 steel wool then wax it to bring the shine back.
    I have found on finishes, especially auto finishes, the thicker they are the easier they will chip.
  • brianwalter
    The Envirotex Lite is an epoxy finish that is primarily made for things like table tops or bars and is generally intended to be poured on and left to flow out evenly. I would think you would have problems using it on something like speakers where you need to cover multiple sides. But it might be worth a try. Google it and read up on it if you want to know more.
    As far as finishing with poly is concerned, I like the oil based versions much better than the water based. Although some of the water based material is getting pretty good and has it's advantages. The oil based poly is a top coat material that needs to be sanded between coats to improve adhesion. It sticks to the previous layer, unlike lacquer which actually dissolves the under coat and becomes one with it, so to speak. It works best if you thin the first coat so that it sinks in and seals the wood, this improves the bond as well. Subsequent coats can be applied at full thickness, assuming you are brushing it on.
    It's generally recommended to use gloss poly on all the build coats and only use a satin (assuming you want that type of finish) on the last coat. The additive(s) that are used to reduce the shine from gloss to satin also blocks some of the light causing the poly to be less transparent. After multiple coats this can become substantial.
    I like to wet sand my final coat with 600 grit or finer sand paper, working up to 1500 or so and then polishing with rubbing compound. If you aren't trying to get a super fine finish like a piano black, you don't need to use a polishing compound. This will leave a slightly dull surface, like a satin finish. If you want a super shiny finish like a Piano Black, you need to use polishing compounds as well and this process will become a lot of work as you will need to spend a little (lot) more time at each consecutive level of sanding/polishing to get all the imperfections out.
    Brian Walter
  • brianpowers27
    Another source for finishing wood with a clear finish and no yellowing of the wood is Enviornmental Technology Inc's. "Envirotex Lite". This stuff is expensive ($22.69 a Qt.) and stinks to high heaven, but leaves a shinny as glass finish. Pour on or brush on and flows out to leave no streaks. Takes time to dry, but leaves a plastic or glass finsih that is clear as a bell!
  • jerryanderson
  • brianpowers27
