strongest joints for box making
  • strongest joints for box making
    what are the strongest joints for box making? i want to be able to build my boxes without screws do to the design i have in mind for the corners, what do you guys do? one of the boxes will be a 10" sub box, will it hold up without screws?
    Re: strongest joints for box making
    Try lock miter joints. They are self locking and are much easier to keep aligned while clamping the joint when gluing. The router bit to cut the joint costs around $40-$50.
    -David
      I like to use 45 degree mitered joints for small enclosures. You apply 2 inch masking tape on the outside of the joints, apply glue to the mating surfaces and close it like a book. If you align them carefully and they are quite small, you may even get by with little or no clamping. I prefer to clamp any way. I try to do four sides and one end at a time to help square every thing up. The mitered joint yields plenty of glue surface area and rounding over the corners still leaves a strong joint.
      More recently I have used a biscuit joiner and biscuits with but* (censor software) joints for larger enclosures. This method makes for even easier assembly than miter joints. It also self aligns and is more stable under clamp pressure. I always oversize the edges and flush trim them with a router after glue up.
      Marv
        Depends on what you have to bring to bear in terms of equipment and skills - dovetail joinery is incredibly strong and has maximum glue surface and is the most self aligning. The next best, as said is locking joinery - also self aligning and lots of glue surface. Next would be half lap with corner blocks to align things for you. And lots of clamps. Lots of clamps. Oh, yeah, lots of clamps.
        When you run make sure you run,
        to something not away from, cause lies don't need an aeroplane to chase you anywhere.
          I agree with David. The lock miter joint works good with MDF, plywood or hardwoods. All you need to do is tap in together and clamp.
          http://www.binkyswoodworking.com/DrawerLockMiter.html
          This link is for drawers but shows two kinds of bits to use. You will also need a descent router table
          Dave
          Trench Seam Method for MDF
            Nice job Bif. Those look great! I haven't done dovetails in a long time.
              Thanks'
                Although more elaborate joints are better, I find that simple b*tt joints are adequate, providing that the edges are nice and square.
                Remember it's a speaker, not a chair... unless you plan on sitting on it or otherwise abusing it.
                Form does not follow function
                Form is simultaneous to function
                  Box joints are also strong and simple -- you can make them with a router or table saw and dado.
                  I've made a jig for TS box joints in about 10 minutes, another 10 or so to get it set up just right, then you can knock out box joints all day long.
                  http://en.wikipedia.org/wiki/Finger_joint
                  And while we're talking joining wood remember that "Finewoodworking Magazine" tested a bunch of different types of glue and good 'ol Titebond was best. "Gorilla Glue" came in at the back of the pack, especially for gap-filling.
                  I'd suggest you find a collection of FWW and read the articles on the glue test and the joint test they also did -- glue had some really surprising results, joint didn't but was still informative!
                    Much as I would love to take credit for those, the cabs are Cizeks from the 70's, in a beautiful Koa wood - heavy and THICK stuff. As strong as they are ,I had two choices with these, refinish and reuse these for speakers or block up the Dakota while we rebuilt the brakes.
                    The cinderblocks weighed less, so I used them on the brake job, though I think the cabinets are stronger.
                      Just do double layer box for a sub.
                      1) glue it and screw it with 3/4 inch mdf.
                      2) glue and screw in a few braces
                      3) then 1/2 inch mdf over the 3/4 inch mdf .
                      4) glue it and clamp it.
                      5) paint or veneer over the nail less top layer of mdf
                      for subs heavy thick boxes work well. you can do this and then use solid wood over the smooth layer of veneer. lowes sells 1/4 inch pieces of oak and you can use strips of it alternating with strips of maple from this ebay seller see link.
                      http://stores.ebay.com/JX3-HARDWOODS
                      these are some nice pieces he has
                      http://cgi.ebay.com/I1025-GOLDEN-CUR...742.m153.l1262
                        thank you everyone for your suggestions, i think i have an idea of where i am going now.
                        thanks
                          I have the jigs to do the elaborate joinery and use them for furniture. For speaker cabinets a simple **** joint works fine with cleats on the interior. I use a brad nailer to hold it together while gluing.
                          How durable are they? I had suspended a 3 cubic foot sub enclosure about 6 feet off the shop floor to get it out of the way while building another one. You guessed it, the hook failed and it landed on one of the corners. The joints held but the corner required a half a can of bondo to straighten out.
                            A simple rabet joint will work well with MDF or plywood. Modern glues (e.g. Titebond) are really, really good. -- Doug
                              Hello,
                              as my skills in woodworking are limited, I use ordinary nails and white wood-glue. After that I brace all the bonds on the inside with hardwood of abt 1"x1". See my folders for details.
                              Regards//Lasse
                              Perry Mason talking to his dentist:
