8 Inches of Fury
  • #16
    Re: 8 Inches of Fury
    Originally posted by dubbreak View Post
    Why 8"?
    While it could give you a small box a 10" will generally be more efficient and a 12" even more so and will go deeper than a poor little 8.
    What are the size restrictions for the sub enclosure?
    Thinking outside the box. Just looking for something different. Thinking that the smaller driver will have better transient response. I could be way off though.
    • #17
      Want great sound, good transient response and a driver that wont break the bank. Get the Dayton Reference 10" or 12". They're very musical in a small sealed box, might not shake the foundation but they sound darn good. They can shake the house in a ported box but the box size is about double. They make a reference 8" sub as well but considering the price and box size there aren't many reasons not to go with the 10 or 12.
      I picked up some great little TangBand 8" drivers off e-bay for about $10 each with free shipping... But I bought 6 of them.
      • #18
        Transient response is more or less moot in the non-directional frequencies. What counts is moving air, and an eight will only move so much before distortion becomes far more of an issue than anything else.
        www.billfitzmaurice.com
        • #19
          The "small driver means better transient response" idea doesn't really hold up, especially since you'd be likely to end up porting that small driver. Transient response isn't just based on the moving mass. It's also based on the motor design.
          nothing can stop me now
          • #20
            Any of the TC Sounds based 8" drivers aren't bad, and the JL 8W7 is nice too. However, I'd just go for a 12" driver that will give the same performance for less money.
            • #21
              Dont forget about the Dayton Reference 8in... from my usage though, i have had two 8in 740c's in sealed boxes. they were wired in parallel to a 150watt@4ohm play amp. with 3db@40hz from the receiver music and ht was nice imo. i think the parents living room is bigger, as it is open to the dinning room, kitchen, front room.
              some may not like me posting this link
              http://techtalk.parts-express.com/sh...8&postcount=18
              however i thought it was a good idea about getting the 740P/C to play lower in a larger box. im always for tinkering with things, sometimes we have to think outside the box.
              *note: i take no sides in about "speaker shaping circuits". all i have to say is, i got my 740C's way back on sale, if i can do a bit of modifying to get them to play lower. As well as use all that Xmax with 150watts or lower, im all for it!
              • #22
                How to grade this objectively? So far I have... "group delay, over rated," and "ratio of inductance to driver size, unspecified".
                Joe.
                New to speaker design? Click here.
                • #23
                  I suspect the OP needs a tiny box due to WAF. Is this correct OP?
                  Objectively, the two top performing 8" drivers would be the Sound Splinter RL-I 8" and JL 8W7 8". These will outperform most 12" conventional subwoofers. The Sound Splinter is a premium TC Sounds designed and built driver, rebadged and sold by Sound Splinter. It is currently out of stock and will not be in stock for a few more months. You need to provide 500 clean watts to these 8" drivers.
                  -Chris
                  • #24
                    Dayton's 8" RS sub and TangBand's should work for you. 8's are about 33 sq.in., 10's about 50, 12's about 80. If they all have the same Xmax, to equal a 12" sub, you'd need about 2-1/2 8"ers, or 1-1/2 10"ers. The larger drivers will TYPICALLY be more efficient (more SPL out with fewer watts in). Bigger boxes are easier to tune (low) than small boxes.
                    You can get a sloppy vented box by poor selection of volume and tuning, as you can get a boomy sealed box with poor volume selection. Both can sound excellent if designed properly.
                    • #25
                      -Chris
                      Outperform most 12". What does that mean?
                      The 8w7 does have an impressive 19mm xmax (one way), but it needs it with it's rated efficiency of 82.7 dB. Plus it's 3ohm, plus it has a high FS for home use (good luck getting a sealed box to dig deep). Might work in a car where you have cabin gain working in your favor, but even in a car I'd prefer efficiency.
                      Compare it to the 12W7 and you'd need to throw at least twice the amount of power at the 8 to get as loud.
                      For the price of 1 8w7 you could get 4+ tang band w8 neo subs. There are plenty of amazing 12s less than that price as well.
                      Don't get me wrong. The W7s are impressive and I'd love a 12 or 13 but the 8 is a waste of money in my opinion. If you can only run 1 8" sub, yeah it's an option I guess.
                      • #26
                        The O Audio 500 is perfect. It has a parametric band to boost the natural F3 of 42Hz to 32-35Hz (you need to do the same with virtually any 12" as well) and has a good matching power output, ideal for the JL. Also, the 8W7 is actually, nominally, a 3.9-4 Ohm driver. I have no idea why they list it as 3 Ohm; actual testing of the units shows it is about 4 Ohms, nominal. Also, the listed VAS is actually much less than listed by the factory specs (and this is consistent for 4 samples I have measured).
                        It means that it produces the same, or more, clean SPL down low, as a conventional design high quality 12". And it does this via it's unusually linear long stroke motor and suspension. Most drivers will not even produce the SPL you estimate in a modeling program due to real factors such as motor non linearity and power compression. The W7s, however, actually perform almost exactly as they model at high power. IN addition, this '8' is closer to a 9-9.25" woofer in actual surface area due to it's extended cone and surround diameter, and it's unique method of mounting (the mount ring is actually behind and under the surround, so no surface area is wasted by placing the mounting ring on the front surface edges).
                        Well, that's comparing extraordinary woofer to extraordinary woofer. I was comparing the W7 to conventional subwoofers (Peerless XLS, Dayton RS, Infinity Kappa Perfect, etc.) of high quality design.
                        The 8W7 is $250 from online discount sellers. 4 of those TBs will run about the same price, and produce perhaps marginally more output compared to one 8W7, and use far more volume/larger cabinet to do it. One can always take multiples of a driver to 'cheaply' gain SPL. But the 8W7 is key where you want substantial output in a tiny space.
                        The 8W7 has been compared to conventional 12" drivers in the real world, and it constantly produces as much, or slightly exceeding SPL, compared to a conventional 12" high quality subwoofer, in many cases.
                        I have also used W7 drivers, including the 8" units, and it indeed has the advantage of producing substantial SPL in tiny boxes. BTW, just like most any woofer, it needs some LF EQ compensation, but it's extraordinary motor allows it to easily take the power and excursion to produce clean, dynamic SPL down to 32-35Hz, just like a good conventional 12" in a sealed cabinet. It can be used down to 20-25Hz, but it's dynamic ability suffers, just like a conventional 12" subwoofer, which also has to strain to go to 20-25Hz. However, like a conventional 12, you can put it in a proper ported alignment, and it will produce clean dynamic output down to 20Hz easily. The entire reason for suggesting the W7 8 was due to it producing a lot of LF cleanly in a tiny tiny cabinet.
                        -Chris
                        • #27
                          8" RS sub is great for music but you will quickly run out of steam with HT. Also the box is not as small as you could get with some others.
                          Going a bit out-there, if you want big bass without using floor space have you thought of an IB setup firing up from the basement?
                          • #28
                            Has anyone used the CCC Trio 8 yet?
                            Why not 2 l/r separate enclosures with one driver each running of a single mono amp?
                            • #29
                              Two separate cabinets, one placed near each main, and using appropriate active crossover to high pass the mains and low pass the subs, will get you better results in so far as integration/seamless transition, in most cases. Most beneficial for music, of course.
                              -Chris
                              • #30
                                -Chris
                                Would you need to high pass the mains?
