Flex Your PCD Mettle:
  • Flex Your PCD Mettle:
    CONTENTS:
    Round #1.0: EconoWave Standard --> Summary
    Round #2.0: EconoWave Deluxe --> Summary
    Round #2.1: EconoWave Deluxe HO --> Summary
    Round #2.2: EconoWave Delite 12 --> Summary
    Round #3.0: EconoWave Delite 10 --> Summary
    Round #3.1: EconoWave Delite 10e --> Summary
    Round #4.0: EconoWave SA, aka "SpitWad" --> Summary
    Round #4.1: EconoWave 4x --> Summary
    Round #5.0: EconoWave SR --> Summary
    Round #5.1: EconoWave SR Compact --> Summary
    Round #6.0: Econowave HP - High Power Pro --> Summary
    Round #7.0: EconoWave Altec 414Z --> Summary
    Round #7.1: EconoWave Altec 414-8B --> Summary
    Round #8.0: EconoWave Mini S-8 --> Summary
    PROJECT MATRIX:
    NOTE: The product code for the Dayton KD trapezoid cabinet kit has changed:
    http://www.parts-express.com/pe/show...24&FTR=245-324
    MEMBER PROJECTS:
    edlafontaine - Delite 12
    winkun - Delite 10
    stgdz - Delite 10e
    Flacjunky - SR Variant
    bruson - Engebretson
    Cerdic - EconoWave SR
    RESOURCES:
    Buyout E-Wave Minis:
    Beta-8A & XD120 in KLH-24
    BAH! Can't upload FRDs; they're 19.6 Kb with minimum phase, 512 pts. Shall I strip the phase or redo them with lower (256 pt.) resolution? Strip readings below 100 Hz? Zip them? (Never done that.)
    Here they are as image:
    ZMAs below.
    C/C distance 10.5"
    HF front plate ~2" behind LF
    Drivers measured via windowed MLS (185 Hz min resolution) on-axis @ 44", 1/6 octave smoothed.
    Target: 1.5 kHz acoustic.
    Need more info?
    You show yours and I'll show mine.
    [Y'all go first.... ;) ]
    Re: Flex Your PCD Mettle:
    Is this on the tweeter-axis for both plots? Or separates?
    Then you would also need to measure offsets, cab-size, edge-treatments, etc and post those too.
    I have a few other ones to sim first...
      http://www.parts-express.com/pe/show...number=245-325
      [This is a 100% Parts Express dealio.... ]
        ZMAs below.
        C/C distance 10.5"
        Need more info?
        You can upload the FRDs. you just need to compress them into a ZIP file first.
          This get it?
          I had already converted them to text for uploading, so have to rename .frd to use them, maybe?
          Do they yield the curves as posted in the image above?
          Hmm ... looks like I could have zipped the folder instead of individual files, without renaming them. Does that work?
          Q: Is the formula bar supposed to be open? I can't save sessions with the values and files intact, but don't want to bug Jeff about that 'til I figure out if I'm doing something stupid. The saved session files are <1Kb, and I have to input everything manually each time I shut down....
            This get it?
            Yeah, you didn't have to rename them to txt files before adding them to the zip, and yes, you could have zipped the folder.
            Would you say that the acoustic centers are pretty close (about the same depth from the baffle?
            I'll get back to you shortly. let me play with these for a bit.
              This get it?
              Q: Is the formula bar supposed to be open? I can't save sessions with the values and files intact, but don't want to bug Jeff about that 'til I figure out if I'm doing something stupid. The saved session files are <1Kb, so I have to input everything manually each time I shut down....
              The file is programmed to not allow you to save it with anything in it. It is a much larger file than you might think. However, if you save out your session. Then the next time you need to load the frd, zma, and csp files and everything will be back where it was - no need to enter everything manually beyond that. The program has always worked this way for a number of reasons. I may consider changing that for the final edition someday.....;)
                ZMAs below.
                C/C distance 10.5"
                Need more info?
                13 components, 5 on woofer, 8 on tweeter. 1KHz LR4. I finally saw the acoustic center info you mentioned.
                  The HF front plate is ~2" behind the LF. Various iterations in PCD have given me different offsets with phase aligned on the known forward axis, but the current one is 62mm.
                    So I need either to save the current session as a new file, or delete the old one first? And reload ZMA and FRD each time?
                    I mention the formula bar because some values are not ending up in the correct fields on reloads. Sounds like I may be reloading an earlier screwup and need to start from scratch with the session files, maybe.
                      Give the session files different names - no need to delete any. I have dozens; the names tell me what they are for. Yes, reload the frd and zma each time. If you know where the files are then it is really pretty fast.
                          Looks good, Pete! Where is the forward axis?
                          1KHz is likely too low for D220Ti, and this waveguide has lost vertical pattern control down there, as well. I'm at 1.8 KHz, 6 components, 2 on woofer, and 4 on tweeter, but I'd sure like to get down to ~1.5 KHz, with the forward axis just above the midpoint between the drivers....
                          I was using tweeter axis.
                          Also, I was trying to avoid that nasty resonance area in the woofer if possible. I didn't know enough about the tweeter to know where to cross it and figured the lower, the better from an acoustic center perspective.
                          I'll move up the targets to 1500Hz and see what happens.
                            Yes, and I'm too close to it; you've notched it down hard, looks like....
                              Well, I reset the targets and took another shot at it. I still have more components than you, mainly to take care of that resonance and give the woofer a smoother roll off. 4 on the woofer, 5 on the tweeter to do some shaping as well.
                              Also, the targets are no longer LR4, but some other setup. With the driver arrangement you are showing, tweeter under woofer and tweeter wired positive phase, there's a very wide lobe, forward and above the tweeter axis. Invert the tweeter polarity and the lobe is below, with almost no change to response on axis.
