Flex Your PCD Mettle:
  • Second round of pics.
ID:	1444855 Click image for larger version
ID:	1444856 Click image for larger version
ID:	1444857 Click image for larger version
ID:	1444858 Click image for larger version
    • Third round of pics.
ID:	1444861 Click image for larger version
ID:	1444862 Click image for larger version
ID:	1444863 Click image for larger version
ID:	1444864 Click image for larger version
ID:	1444865 Third round of pics.
      • Last set of pics.
ID:	1444867 Click image for larger version
ID:	1444868 Click image for larger version
ID:	1444869 Click image for larger version
        • I'm super tired, been working all day.
          Just also noticed that the B52 flange is 1/4" wider and nearly a 1/4" taller.
          And the bolt holes do not line up.
          This goes along with it being more heavy-duty than the OEM QSC product.
          Pics...
          Click image for larger version  Name:	IMG_20200625_205523.jpg Views:	0 Size:	676.3 KB ID:	1444874 Click image for larger version  Name:	IMG_20200625_205503.jpg Views:	0 Size:	806.5 KB ID:	1444875 Click image for larger version  Name:	IMG_20200625_205516.jpg Views:	0 Size:	762.2 KB ID:	1444876 Click image for larger version  Name:	IMG_20200625_205540.jpg Views:	0 Size:	745.2 KB ID:	1444877 Click image for larger version  Name:	IMG_20200625_205511.jpg Views:	0 Size:	745.2 KB ID:	1444878
          • Last pics, for real this time.
ID:	1444880 Click image for larger version
ID:	1444881 Click image for larger version
ID:	1444882 Click image for larger version
            • Originally posted by Pete Schumacher View Post
              Re: Flex Your PCD Mettle:
              I took those individual curves and applied the offsets based on the PCD summed and measured summed response. I set the woofer forward of the tweeter by 60mm and the woofer .125 meter below center and the tweeter .125 meter above center.
              L2 = 4.5mH .3 Ohm
              C2 = 12uF
              C9 = 5.6uF
              R10 = 4.7 Ohm
              R16 = 2.7 Ohm
              The forward lobe looks very good, especially moving toward and above the tweeter position. the overlay is 45 deg above center point.
              I know this is older but is the "shortened list" here for the slandered version?
              • Another question, maybe to Pete:
                If I build myself a cabinet and want to stick to the Dayton trap-cab dimensions so to not mess up with baffle step: What is the baffle width I ought to choose? Because the front panel is inset and it's maximum width should be reasonably less than the total width at the frontend of the side panels, which is either 15,523 " (inner) or 16,907 " (outer).
              • hey djg,
                thanks for your experience! how wide is your cab?
                I thought there would be a math-based truth about that, though. Like, with OB people, baffle width is also extended into depth, does this also apply to infinite baffles like a box? then, the protuding edges of the dayton cabinet would actually add to the baffle width, not the othern way. I don't know, someone who knows the mathematical foundation probably does.
                • djg
                  djg commented
                  Editing a comment
                  Cabs are 15 3/4" wide, baffles would then be 14 1/4" wide with a raised 3/4" edge. Everyone's right about a raised edge, I built for a vintage look. I have lots of "proper" speakers. Those Pioneer cabs were $25 and they still worked. I could have put a flush baffle in but I didn't. There they are.
                  I bet they have more Craigslist resale value as is.
              • Originally posted by sheeple View Post
                hey djg,
                If you're talking about the outstanding edges around the old trap box, those aren't a real good idea for hi-fi. You'll get gobs of diffraction off them. There's a reason quality speakers for home use don't do that anymore. For Pro use, indestructibility is a big consideration.
                Francis
                • sheeple
                  sheeple commented
                  Editing a comment
                  Shure, I wouldn't inlude them in my build (although there were plenty of high end JBLs/Klipschs with those outstanding edges. And also Zilch wrote, he couldn't really hear the effect and wasn't even quite shure, whether the visible meassurement shifts where caused by the foam or the wood edges). I'm interested to keep the baffle dimensions the "same", so the crossover works.
                  It is not obvious to me what is the width I need to orient to: https://www.parts-express.com/pedocs...nual-43166.pdf
                  Width of inset panel (to be calculated), width between outstanding edges (15,523"), width total with outstanding edged (16,907"), maybe even adding their depth to baffle width?
                • djg
                  djg commented
                  Editing a comment
                  Vintage cabs for vintage ears.
              • Originally posted by Zilch View Post
                Here's mine:
                IS there a more idiots guide to connecting the L-pad? for someone not using PCB
                • AEIOU
                  AEIOU commented
                  Editing a comment
                  3, 2, 1. Terminal 3 from the amp through the crossover. Terminal 2 to the tweeter. Terminal 1 common return, back to the amp.
              • AEIOU
                So 3-before XO Tweeter, 2 After XO Tweeter, 1 common ground?
