Flex Your PCD Mettle:
  • Re: Flex It Round #3.1 - EconoWave Delite 10e:
    Originally posted by A9X View Post
    Looking forward to seeing how this comes out. What CD are you using?
    The one QSC uses with it:
    http://professional.celestion.com/pr...etail.asp?ID=3
    • Re: Flex Your PCD Mettle:
      FRDs below.
        ZMAs:
          Zilch,
          Is it my imagination or is the build that you did with the XT1086 / DE250 combo still the best? I just went looking thru the thread to confirm my suspicion but didn't find the post where you tested it.
            I didn't get around to trying the BMS 4550 and 4552nd on the XT1086, but will get back to that. Clearly, that horn/waveguide played the flattest of all of these builds using DE250, but if I had to choose, my favorite is still eWave Deluxe.
            Constant directivity is the defining characteristic of all of them, and once they're playing with equivalent frequency response, differences in how the high frequencies sound are subtle. There's a very real sense in which all eWaves sound alike once the basics are in place and "normalized."
            Total system voicing depends more on what woofer is used in combination, its low-frequency extension and midrange clarity. Disconnect the woofers, and it's surprising how little the waveguides are actually contributing, but that is hugely important with respect to the sonic character, as it's controlling the interaction with the listening space....
              Zilch, what is the mic distance and driver placement relative to the mic location?
              I'm getting ready to PCD it and would like to get the vertical offsets from the mic location so I can see if I can pull out the Z offset from your published data.
              Thanks
                Once again, awesome guys!!
                Zilch, why did you choose to 1425 over the 1745? The 1745 would have been easier to manage down low.
                  Ooops, mic distance 44", c/c = 10" (I'll confirm that), and all measurements from midway between woofer and waveguide centers.
                  Hi, Penn. 1425 because that's what QSC uses in 122i, no?
                  [It's also cheaper.... :D ]
                    One last question.
                    What's the opening diameter of the WG?
                    Looks like the woofer acoustic center is about 40mm in front of the WG acoustic center.
                      Very cool, boys.
                      http://www.nytimes.com/2010/10/14/bu...html?src=busln
                      http://mixonline.com/mag/audio_new_york_metro_46/
                        Is there any more available from that tweeter? I'd sure like to see just a tad more output from it on the top end. Sure would make tweaking the response a bit easier.
                          One last question.
                          1" throat on the compression driver/waveguide.
                          First shot at Z is delta 62 mm from the measured inverse null location.
                            Are you padding the tweeter with the L-pad to that level? Can you set it for just a tad more output at the high end?
                              Yes and yes; we can probably grab as much as 1.5 dB more. It's set at 1:00, and up to 3:00 would be fine.
                              C/c distance is 10.6875".
                              For wavelet heads:
                                Yeah, the 1425 is what is in the 122i, the 1745 is in the 152i but the 1745 fits the 122i waveguide also and I remember it being maybe $10 more for a better response.
                                I will ship you the 1745 if you guys wanted to switch? btw, I just received some Radian 745Bs so I have a new build with rear-mounted woofers, etc.
