Flex Your PCD Mettle:
  • Re: Flex Your PCD Mettle:
    Originally posted by Erich H View Post
    On those 2510's, if the boxes were ported and tuned around 70hz or so, do you think that would be enough for a center channel? Or would it not give enough powerful bass output? I'm not sure what a center channel needs to go down to and I know most cross them over around 80hz.
    I use an eWave with the 2510 for my center channel. The XO from the subwoofer is set to 80Hz and the center channel is set to "small" so the center channel really doesn't see much, if any, low bass. It seems to work for me.
      Don, is your center ported or sealed? By crossing over at 80hz it probably doesn't matter much.
        Hey Zilch, how do you think that the Deltalite 2510 would work with the XD120?
          I'm just now gathering the data on it with the 8" 228H. It's gonna cross ~2.1 kHz; 2510 can play that....
            Ported, tuned to ~60 Hz I think.
              I think that sounds great. I'm looking at something sort of similar, at least I think so. :D
              On those 2510's, if the boxes were ported and tuned around 70hz or so, do you think that would be enough for a center channel? Or would it not give enough powerful bass output? I'm not sure what a center channel needs to go down to and I know most cross them over around 80hz. But I'm debating if I should also put two NHT 083's in with my center channel and use the B-20 amp. Might be too much overkill though.
              How long before you start your project? I can't wait to see it.
              I've built a few test boxes for the 2510 Erich and IF you're crossing at 80hz to a sub, i would recommend sealed in .75 cuft for heavily stuffed for an F3 of 100hz....keeps the midbass clean and vocals super intelligable.
                UT-oh:
                60095/875=68.6800
                  Originally posted by Zilch View Post
                  UT-oh:
                  60095/875=68.6800
                  Ling Tempco Vought !!!!
                    Playing on the reputation of the F4U Corsair . . . ah, the sound, the sound . . .
                    "It suggests that there is something that is happening in the real system that is not quite captured in the models."
                      Bought Altec in 1959, apparently:
                      http://en.wikipedia.org/wiki/Ling-Temco-Vought
                      Supplied Woodstock in 1969, and spun off 1974.
                      I'm bettin' these be good'uns, 8 Ohms to boot.
                      [Whatever shall I mate them with...? :p ]
                        oooooh.
                        UT-oh:
                        60095/875=68.6800
                        http://www.nytimes.com/2010/10/14/bu...html?src=busln
                        http://mixonline.com/mag/audio_new_york_metro_46/
                          What say 152i w/BMS 4552nd, Skywave?
                            I'm good with that.
                              Zilch,
                              Any idea how efficient (1 watt/1 meter) all of the speakers in post 1 might be? Got a buddy that is looking for a new set of speakers to drive with a low wattage tube amp.
                              Thanks,
                              Scott
                                The Eminence Deltalite 2512 and Kappalite HO, with eff's of ~ 99 dB, result in speakers of ~95 dB efficiency, after baffle step. The Deltalite 2510 is ~2.5 dB less, so it comes in around 92.5 dB.
                                The mid-bass efficiencies are the determining factor...Deduct ~4-5 dB from that.
                                Mongo only pawn in game of life
                                ____
                                Ed
